2 EMGs in a 5-way VLX91? help please! - Jemsite
post #1 of 26 (permalink) Old 05-28-2007, 02:01 PM Thread Starter
excuse me if it's already been discussed, but couldn't find it.
i've been asked to put two EMGs in place of two DiMarzio/IBZ on an RG2020 which has got a VLX91 5-way switch. now, the DiMarzio/IBZ have 4-conductors and coil-splitting and whatever, and, as you know, the EMGs aren't splitting and have only 2 conductors. can anyone help me find whatever wiring scheme for that? no matter what's in positions 2-3-4. thanks in advace.
nuno is offline
post #2 of 26 (permalink) Old 05-28-2007, 02:10 PM
Re: 2 EMGs in a 5-way VLX91? help please!
That's pretty easy Nuno.. if you don't care what's in positions 2-3-4 you can wire it up pretty easy. Give me a second to pull up the proper pin configurations for a VLX-91 and I'll tell you how to wire it.
buddroyce is offline
post #3 of 26 (permalink) Old 05-28-2007, 02:11 PM
Did you want
Neck, neck, both, bridge, bridge
or
neck, both, both, both, bridge?
(or even something as silly as neck, bridge, both, neck, bridge?)
post #4 of 26 (permalink) Old 05-28-2007, 02:30 PM
Here's a quick diagram I did up for ya for 2 EMGs on an OTAX VLX-91 switch
1 Neck, 2 neck, 3 both, 4 bridge, 5 bridge
http://www.brlguitars.com/2emg_on_5-way_vlx91.gif
Pretty simple ain't it??
Let me know how well it works. I just conceptualized the wiring right now and haven't personally tested it. It should work though. The logical flow of the signals only mix through the switch and shouldn't bleed onto each other.
You can mod this wiring very easily to get neck, both, both, both, bridge if you want.
post #5 of 26 (permalink) Old 05-29-2007, 04:08 AM Thread Starter
Budd, you're the man! thank you a lot! very easy, indeed, but i just can't get into those electronic stuff. it would be so cool and usefull to know how the switch pins connect each other, so ppl like me would stop bothering ever.
btw, how would it change if i wanted to try the "neck, both, both, both, bridge" config? just out of curiosity. thank you man!
nuno is offline
post #6 of 26 (permalink) Old 05-29-2007, 09:52 AM
Going from "neck, neck, both, bridge, bridge" to "neck, both, both, both, bridge" is stupidly easy. Here's a variation on the same wiring as before to give you both pickups in positions 3, 4 and 5
http://www.brlguitars.com/2emg_on_5-way_vlx91_ver2.gif
Feel free to ask me about wiring questions. I'm *STILL* working on writing a book on guitar electronics and wiring, so any wiring questions I deal with I just add it to the stash of diagrams that will sooner or later go into the book.
post #7 of 26 (permalink) Old 05-29-2007, 10:03 AM Thread Starter
great! Budd you saved my life, and i'll surely been asking you other questions soon! i owe you two, for now!
nuno is offline
post #8 of 26 (permalink) Old 05-29-2007, 10:04 AM
Here's a diagram with the two different versions side by side so you can see the difference.
http://www.brlguitars.com/2emg_on_5-way_vlx91_diff.gif
Now you can see how simple it is to change from one wiring to another
post #9 of 26 (permalink) Old 05-29-2007, 10:05 AM
No problem man. Someone had to finally do a diagram for EMGs on a 5-way, so it might as well be me. Let me know how well it works
post #10 of 26 (permalink) Old 05-29-2007, 12:13 PM Thread Starter
i'll probably try it tonight, i'll tell you tomorrow or so! thanks zillions!
nuno is offline
post #11 of 26 (permalink) Old 05-30-2007, 05:38 AM
ax1
can be buddroyce a good friend and draw me a pic for 5 way switch multi pole and pull pot switch for 3 emgs with the switch like these positions
1:81
2:81 sa
3:81 60 ( pot down) sa by itself ( put up)
4:60 sa
5:60
thanks
ax1 is offline
post #12 of 26 (permalink) Old 06-01-2007, 06:53 AM Thread Starter
here i am Budd, i finally tried the scheme you provided me, and it works great! thank you A LOT man!
ps: let us know when your book is out! you got a buyer for sure!
nuno is offline
post #13 of 26 (permalink) Old 06-01-2007, 10:49 AM
That's awesome!!! Glad it works well!
(I'll be sure to let you know when that book is done..)
post #14 of 26 (permalink) Old 06-01-2007, 10:50 AM
1:81
2:81 sa
4:60 sa
5:60
thanks
Which switch are you using?
post #15 of 26 (permalink) Old 06-02-2007, 03:38 AM
ax1
the one one that comes with rg 370dx and im going to buy a pull pot from stew mac
ax1 is offline
neck pickup
FS: RGA 121 NTF w/ Duncan Invader Installed PLUS EMGs Clypher Classified Ads: Guitars and Gear 5 02-03-2007 03:13 PM
EMG's? dex_ibanez All Other Guitars (including Prestige) 14 08-24-2006 09:15 PM
can EMG's be versitile? Mr. S Pickups & wiring 21 08-11-2005 10:46 PM
RG620X - Installing EMGs... ??? JiMoSiTY Pickups & wiring 3 10-29-2004 10:13 AM
Report: Replacing V7 / V8 with Duncans using VLX91 Alnico5 Pickups & wiring 0 08-28-2003 01:29 PM
