2 Hums, 3 way switch, coil tap bridge? - Jemsite
post #1 of 2 (permalink) Old 02-19-2014, 03:11 PM Thread Starter
So I've been trying to rewire my 350ex, with some 2-wire pickup I found for a neck (temporary), but I can't seem to get my wiring correct. Would anyone be able to tell me if this looks correct?
Going for a double humbucker, 3 way switch, single volume, with the volume coil-tapping the bridge (DiMarzio Evo 2).
draven.bmx is offline
post #2 of 2 (permalink) Old 02-19-2014, 06:14 PM
Re: 2 Hums, 3 way switch, coil tap bridge?
http://www.guitarelectronics.com/product/WD2HH3T10_01/
south start is your green wire, the bare is your ground
north start is you hot/red wire
north finish and south finish are your white and black wires.
if the neck has two wires and only two wires, one is a ground and one is a hot. If it has three wires then one is a coil tap, one is a hot and one is a ground. The only reason i mention it is because some people dont count the ground as a wire.
j.arledge is offline
coil tap vs 2 way mini switch g.milko Polls 3 11-15-2009 10:37 AM
wiring 3 way switch with 2 dimarzio hums (coil splitting) emericanchaos Pickups & wiring 2 05-22-2008 03:16 PM
need help asap with mini switch dp/dt on/on/on for pickup wiring 2 hums ibanezcollector Pickups & wiring 2 07-09-2007 04:30 AM
Hum-Hum, 3-way switch + Coil Tap Switch Wiring TAorama Pickups & wiring 1 06-19-2005 01:12 PM
s1 switch & ibanez s coil tap Screaming Wind Tech: Setup, Repairs and Mods 1 03-08-2004 10:14 PM
