250k Or 500k Pots with Single-Coil - Jemsite
post #1 of 3 (permalink) Old 12-03-2015, 09:05 AM Thread Starter
Hello folks, not posted here in a long, long time. Needing some help!
I have a lovely 1950s archtop guitar (Hofner) with a single low-powered single-coil pickup - due to both pots being seized and the wiring being duff (unsurprising considering its almost 60 years old), this winter's little project is to get it working again.
The original pots are 250k, however I was wondering if 500k pots would be better or worse. The guitar always had a very nice clear snappy tone with lots of presence and low-end, I was wondering if 500k pots would make the tone too trebly or if it would be better sticking with 250k.
Help me choose wisely!
Regards
'87
Shredder87 is offline
post #2 of 3 (permalink) Old 12-03-2015, 02:35 PM
Re: 250k Or 500k Pots with Single-Coil
It doesn't make a radical change, but the higher values give you a more pronounced resonant peak.
Pots , even "fancy" ones, are pretty cheap. If you're comfortable wiring your own guitars, it may make sense to just buy a set of each and try them both, and maybe record some clips to A/B to see which you prefer. It probably won't make a radical difference, though. The 250ks may sound a little thicker and meatier than the 500s, but it shouldn't be night and day.
Drew is offline
post #3 of 3 (permalink) Old 12-04-2015, 05:49 AM Thread Starter
Thanks Drew, based on that I think I'll stick with 250k.
'87
FS: Paf Pro, Fred, Jem Single Coil, Jem Switch and Two 500k Pots wandereruk05 Classified Ads: Guitars and Gear 2 03-16-2011 10:52 AM
Did RG3120's come stock with 250k or 500k pots? SnakeEyes All Other Guitars (including Prestige) 3 07-20-2010 01:58 AM
250K or 500K pots for my HSS Strat make-over? Anyo Pickups & wiring 4 11-18-2009 11:14 AM
do 1990 rg550's have 250k or 500k stock pots? shredder00 Pickups & wiring 1 10-31-2009 04:45 PM
difference between 250k and 500k pots? toma Pickups & wiring 3 01-18-2007 04:46 PM
