are the 3 lug output jacks stereo? - Jemsite
post #1 of 11 (permalink) Old 07-03-2003, 03:21 PM Thread Starter
i am putting emg's into an rg570 and i noticed that the jack has 3 lugs on it. i ordered a stereo jack for my sa160qm and noticed that the both jacks were identical. is the 3 lug jack stereo or mono?
RG7420 is offline
post #2 of 11 (permalink) Old 07-03-2003, 04:49 PM
It's stereo. But i believe you need it for EMG's because it has something to do with the battery turns it off when the cords not plugged in maybe
CrossingStar is offline
post #3 of 11 (permalink) Old 07-03-2003, 07:01 PM
Yess!!!
Itīs for battery deviced Pick-ups or other internal electronic such ass boosters filters e.t.c to save batterypower
JEM10th is offline
post #4 of 11 (permalink) Old 07-04-2003, 12:09 AM Thread Starter
ok so i will be ok with the stock ibanez output jack. it's been a really confusing day.
RG7420 is offline
post #5 of 11 (permalink) Old 07-04-2003, 05:58 PM
Yes, you can use a stereo jack for non-stereo outputs.
Stereo jack can be used to activeate the battery for active pick-ups.
Timanator is offline
post #6 of 11 (permalink) Old 07-05-2003, 09:29 AM
No, actually you will NOT be okay if you use the stock output jack (unless it's a stereo jack already).
If you use the mono jack there will be no way for the pickups to be turned on/off, and you'll either have the battery draining non-stop (you'll pick up the guitar tomorrow and it will be silent) or, depending on your wiring, the pickups won't come on at all.
You need the extra lug, it acts as a switch to turn on the power to the pups, without it things just won't work correctly.
Mic
MicJustMic is offline
post #7 of 11 (permalink) Old 07-05-2003, 02:04 PM
I have been wondering about that as well. Why is the stock Ibanez Jack's 3 prong unless it is a stereo jack?
post #8 of 11 (permalink) Old 07-05-2003, 08:04 PM
A 3 pronged jack is not a stereo jack. As if it was designed for stereo use. Its a 3 pronged jack that happens to be needed in a stereo setup.
Its just a jack made for 2 hot leads and a ground. It so happens that in a stereo signal thats exactly what you need but theres jacks that have more then just that. You wont find those on most audio equipment though.
Theres many different popular guitar circuits that need a standard 3 pronged jack for purposes other then stereo or battery power saving. What would help the most is if you described the controls that were on your ibanez to begin with. It very well could have been stereo but I strongly doubt it.
Dan D Mahnn is offline
post #9 of 11 (permalink) Old 07-06-2003, 12:20 AM
Ah, I was confused, I thought you were talking about the jack that came with the EMGs . . .
I've never had to replace/rewire an input jack on an Ibanez so I wasn't aware that they had/have three prong jacks, but looking at the wiring "diagrams" on Ibanez.com I see that they are indeed three prong.
Hmm . . .
Have to ponder this . . .
Mic
post #10 of 11 (permalink) Old 07-06-2003, 07:13 PM
Are you sure they even used the 3rd prong in the wiring? Look at it and see if all the prongs have solder on them. I forget what brand of guitar, I think Jackson, but I remember opening up one guitar and seeing a 3 way jack but they still only used 1 groung and 1 lead.
post #11 of 11 (permalink) Old 07-06-2003, 07:45 PM
On mine (just looked) there's one that's bare, no connection, as expected.
I assume (ass-u-me) they just buy lots of three lug only and use them for everything.
Easier that way in some respects, just one thing to order, and on the models that need three (like basses with active EQ) you have what you need all in one bin instead of keeping two different kinds at hand.
I'd also imagine that the cost difference is almost moot, since they buy so many of the things in a clip.
Mic
Stereo Output Jack - Cable Question webmaestro Gear, Equipment, Recording & Off Topic 0 01-23-2013 04:37 PM
Wiring a stereo output jack mono nsabino Pickups & wiring 13 09-06-2010 05:50 PM
Why do my output jacks ALWAYS crap out??? Jupiter Tech: Setup, Repairs and Mods 6 05-14-2004 03:53 AM
Stereo output jack? Petie Pickups & wiring 1 05-03-2003 02:26 PM
The best output jacks Contra Pickups & wiring 14 12-06-2002 06:30 PM
