3 way switch issues - Jemsite
post #1 of 5 (permalink) Old 02-13-2013, 08:33 PM Thread Starter
3 way switch issues
Hey - I just replaced the bridge pickup on an import Ibanez - an ART100 - and it works great. But, when the selector is in the middle position (neck PU + bridge PU) the sound is super thin and weak. In the neck position - sounds great. In the bridge position - sounds great. In the middle - sounds weak. I can't think of a reason for it, other than a bad switch - and I can't remember if it did that with the stock pickups (I never used the middle position). Any help would be appreciated, thanks
ColinMmmmm is offline
post #2 of 5 (permalink) Old 02-13-2013, 10:57 PM
Re: 3 way switch issues
Id take really good look at the switch.. take it out and try it while plugged into an amp and see if anything is bent preventing the correct connection. Ive replaced a few in my day
GUITARMAGEDDON is offline
post #3 of 5 (permalink) Old 02-13-2013, 11:26 PM Thread Starter
I would - but it's all enclosed in a metal/plastic casing. I can't see a way to get it open without doing serious damage to it...
post #4 of 5 (permalink) Old 03-13-2013, 10:47 AM
Just guessing, I think your pickups out-of-phasing each other. Try to reverse the polarity of ONE of the pickup.
Example (Dimarzio 4 conductors pickup): change the hot to WHITE (instead of RED). Tape RED & GREEN together, while connect the BLACK & Bare as ground wire.
Or if it has just 2 wires, then switch between the hot & ground wire.
bang_jalil is offline
post #5 of 5 (permalink) Old 03-13-2013, 03:06 PM
to change phase on dimarzio switch the red and green wires. red is the hot wire in all standard configs and green is run with the bare to the ground.
make green your hot and run red to the ground.
it does sound like an out of phase issue, but what pickup did you put in ? and if you could post a picture of the switch and or wiring it would let us take a look and make sure nothing else is off.
j.arledge is offline
Quesiton about corresponding ibanez 5 way switch diagrams for a fender 5 way switch GuitarEvan07 Tech: Setup, Repairs and Mods 0 06-19-2009 08:20 PM
Make a 5 way switch a kill switch? GuitarEvan07 Pickups & wiring 11 04-15-2009 02:19 AM
Could i change the 2 position switch of my RG620x to a 3 position switch? supergirl20_06 Tech: Setup, Repairs and Mods 4 05-10-2007 04:27 AM
Hum-Hum, 3-way switch + Coil Tap Switch Wiring TAorama Pickups & wiring 1 06-19-2005 01:12 PM
HELP Switch Issues Two hands31 Pickups & wiring 3 01-05-2003 08:42 PM
