5 Way Switch Ibanez Stock - Jemsite
post #1 of 6 (permalink) Old 02-19-2012, 01:34 PM Thread Starter
Hi, all.
I want to ask if it is possible to have this config for an H-H config:
1 - Bridge series
2 - Bridge Parallel
3 - Bridge and Neck
4 - Neck Parallel
5 - Neck series
Is this possible for a stock Ibanez 5-way switch? Currently the config is much like Paul Gilbert's PGM401:
1 - Bridge series
2 - Bridge inner coil + Neck outer coil
3 - Bridge and Neck
4 - Neck Parallel
5 - Neck series
I did not like the volume loss of the bridge inner coil + neck outer coil and I found it unusable on cleans and distorted tones. Will parallel-ing the bridge pickup be usable and will I be able to get that "quack" and chime will still maintaining humbucker power?
ermonski is offline
post #2 of 6 (permalink) Old 02-19-2012, 04:27 PM
Reviews: 120
Re: 5 Way Switch Ibanez Stock
The standard fender style 5 way that most HSH Ibanez guitars use won't work. You need a 3PS1SC5 switch as found in most HH Ibanez guitars.
LonePhantom is offline
post #3 of 6 (permalink) Old 02-19-2012, 10:11 PM Thread Starter
I own an Ibanez RGR321EX with an H-H config and 5waty switch, will the config be possible?
ermonski is offline
post #4 of 6 (permalink) Old 02-20-2012, 07:56 PM
Reviews: 120
Ah, sorry. You'll have the switch I mentioned. I'm not sure if the config you want is possible. You may need a mega switch or something similar. They are insanely complex, but can do pretty much anything.
post #5 of 6 (permalink) Old 02-21-2012, 09:00 AM Thread Starter
thanks!
I'm thinking of converting to a 3-way switch, but with the tone and volume pots as push-pulls (volume push pull for bridge and tone push pull for neck). Will that give me the versatility? Or will replacing the tone pot with a 2-way toggle switch do?
ermonski is offline
post #6 of 6 (permalink) Old 03-03-2012, 04:13 PM Thread Starter
how about an Allparts 4-pole 5way switch?
ermonski is offline
ermonski , ibanez , jemsite , stock , switch
Problems re-wiring S7420 with Dimarzios and stock 3-way switch. Kowalski3500 Pickups & wiring 6 02-28-2011 01:43 PM
Stock 5 Way Switch Popping Noise DogRox Pickups & wiring 14 12-22-2009 09:01 AM
replacing stock switch kizo Pickups & wiring 3 10-04-2007 06:37 AM
Need Pin-Out for Ibanez Stock 5-way Switch racerevlon Tech: Setup, Repairs and Mods 7 05-24-2007 06:04 PM
RG7620 5 Way Switch - Stock? CrossingStar Pickups & wiring 9 08-23-2003 05:50 AM
