Air Norton S as Middle Pup - Page 2 - Jemsite
LinkBack Thread Tools
Old 09-14-2014, 02:55 AM Thread Starter
tundrastruck's Avatar
Re: Air Norton S as Middle Pup
Takin A Ride, here's my revised scheme. Will this work pickup wise?
tundrastruck is offline
Old 09-14-2014, 06:29 PM
I'm not 100% sure I follow your wiring diagram but here's how DiMarzio thinks you should wire that:
http://www.dimarzio.com/sites/defaul...plit2and4C.pdf
You have to flip the neck pickup so that you're getting the inner coils I think. Or do you mean you want the south coil of the neck pickup with the pickup in normal orientation?
Obviously you'd have to make some slight adjustments for the dual tone pots. You could use this for the tone controls:
http://www.dimarzio.com/sites/defaul...ck1tbridge.pdf
DiMarzio's wiring diagrams leave a little bit to be desired since they don't mention pickup orientation or which coil they're referring to.
Takin' a Ride is offline
Old 09-14-2014, 07:07 PM Thread Starter
I understand, the scheme I posted is actually using the wiring from the second pdf you listed there. Theres no mention of having to flip pickups , but I guess I'll learn quick when I get the wiring done whether it works or not.
Old 09-15-2014, 09:01 AM
Yeah, I think experimentation is the best way to figure this out.
The way I've seen Strats explained is that the middle pickup is always reverse polarity. In order to get a full sound in positions 2 and 4, you want both a reverse polarity middle pickup AND you want to wire it in reverse. Old Jems are this way:
But take a look at the diagram for a Jem20th using a hum-cancelling middle pickup:
http://www.ibanez.com/supportResourc...07/JEM20TH.pdf
It's wired backwards like I would expect, but it still seems to me like you're getting two north poles active in positions 2 and 4.
dimarzio , norton , pickup
WTT Norton or Tone Zone for Air Norton or Fred... gauchosilvertone Classified Ads: Guitars and Gear 11 06-03-2012 03:02 PM
Tone zone/evolution middle/air norton? Gastricsumo Pickups & wiring 19 04-16-2011 05:14 AM
DiMarzio Air Norton (zebra) / True Velvet Middle jam3v Classified Ads: Guitars and Gear 3 10-26-2009 10:34 PM
WTB: Single Coil Size PUPS for neck/middle like Air Norton S or Area 58 or similar jumpinjackf1ash Classified Ads: Guitars and Gear 4 02-24-2009 08:32 PM
Is a air norton the same as a regular norton as far as the way it is wound? Roadstar Pickups & wiring 2 09-21-2006 08:46 PM
