Anyone know how to wire a stock ibanez for dimarzio ! Please help :) Im desperate - Jemsite
post #1 of 9 (permalink) Old 05-11-2005, 07:01 PM Thread Starter
hi there,
My old Ibby humbuckers have is a red wire, a white wire, and a super FAT bare wire. The superfat bare wire is going to ground i think, as it is soldered onto the back of a pot. And both the red and white wires are connected to the pickup selector poles.
Im changing the Ibanez neck pup for a Dimarzio Breed, but what the heck do i solder... and to what? I've tried one or two combinations but it always leaves the breed out of phase with the old ibanez SINGLE coil in the middle. The breed works great, the single coil works great, but together the tone is tingy and weak, which spells out of phase to me.
I'm a complete pup newb so im really desperate.. or it'll have to be a tech
Please help if you can..
Kev
themaidenmaniac is offline
post #2 of 9 (permalink) Old 05-11-2005, 11:02 PM
Re: Anyone know how to wire a stock ibanez for dimarzio ! Please help :) Im desperate
try swapping the positive and negative wires of the single coil.
Rotti is offline
post #3 of 9 (permalink) Old 05-12-2005, 12:59 AM
Try Rotti's suggestion, but I would make sure the Dimarzio's wired okay first:
Dimarzio red where the stock red was.
Dimarzio black and white(soldered together) where the stock white was.
Dimarzio green and bare(soldered together) where the stock bare was.
toshiro is offline
post #4 of 9 (permalink) Old 05-12-2005, 01:52 AM
As requested:
http://www.tremol-no.com/images/DiM_8poleRev2.jpg
Other Ibanez wiring diagrams can be found here:
http://www.ibanez.com/wiring/models.asp?t=e
Kevan is offline
post #5 of 9 (permalink) Old 05-12-2005, 04:50 AM Thread Starter
Thanks guys, im gonna get wiring this morning in the hope of finding an antidote !!!
post #6 of 9 (permalink) Old 05-12-2005, 04:52 AM Thread Starter
Originally Posted by Kevan
As requested:
Hi Kevan, i think i found your site last nite b4 you posted actually! I couldnt find the type of diagram i was looking for tho sadly, as Ibanez pups are a knigtmare.
The schemtaic is also H S H.
post #7 of 9 (permalink) Old 05-14-2005, 11:32 PM
I hope you haven't done the tech thing yet or at least found a site on your own by now. If you go to the DiMarzio site and click any of their pickups, it will have wiring diagrams for several options. The HSH on on there is the typical JEM wiring, and it uses a normal 5 way switch (most techs will say you need a super switch to do it, that's not true). Also, the parallel wiring will make the sound be thin, like a single coil. But if it sounds like a tin can behind a newlywed's car, then you're right, something's wrong. Hope it works!
Praetorian is offline
post #8 of 9 (permalink) Old 05-15-2005, 07:33 AM Thread Starter
I sorted it out finally thanks guys,it involved some very strange wiring antics.
post #9 of 9 (permalink) Old 09-13-2005, 12:36 AM
Kevan, can you please put the wiring diagram back up on your site? I opened it, and all it says is donkey punch.
Kindred_Spirits is offline
dimarzio breed , ibanez neck , ibanez wiring diagram , neck pup , wiring diagram
WTB: Set of stock F1 /C3 /F2 Ibanez Dimarzio Pups Dr.StrangeNote Classified Ads: Guitars and Gear 2 10-25-2009 06:20 PM
Ibanez and Dimarzio wire colors cjl5150 Pickups & wiring 2 11-19-2008 09:43 PM
ibanez vs dimarzio pup wire colors xeroparadox Pickups & wiring 3 05-20-2007 01:13 PM
Ibanez Stock 5-way vs Dimarzio's Diagram?? Help?! torque Pickups & wiring 2 03-28-2006 11:21 AM
Ibanez/Dimarzio Pickup wire colours Blues-core Pickups & wiring 8 07-08-2003 04:18 AM
