Blower Switch Wiring - Jemsite
post #1 of 5 (permalink) Old 11-10-2010, 11:24 AM Thread Starter
As I'm sure you're all aware, the new Suhr Guthrie Govan mahogany signature model is awesome http://www.suhrguitars.com/artistMod...px?series=ggsn
The part that catches my eye is the blower swith. For those of you that don't know, it's a cool idea: push it, and you get full bridge humbucker, volume pot, tone pot and other pickups all bypassed. Push it again and the guitar reverts back to whatever selection you had beforehand. Awesome.
I was looking around for a wiring diagram, since a 'solo' button sounds like a cool thing to add to my project strat, and it's harder than I thought. I got one website telling me you need a 3pdt switch, and apparently Suhr themselves use a dedicated PCB board.
Wait? A dedicated PCB board? I've a better idea.
I think it can be done with only a SPDT ON-ON switch. I've yoinged a wiring diagram from Seymour Duncan, since that's what I have in my strat, and have added what I think will work. I think at the moment if the pups are coil cut, you get a coil cut full bridge pup.
http://tinypic.com/r/ta662o/7
or
http://img829.imageshack.us/img829/6...itchwiring.jpg
What I'm asking is, will this work? Have I missed something? It looks good to me, but I'm no expert, and you guys are.
Any help would be very much appreciated.
Zatarna is offline
post #2 of 5 (permalink) Old 11-10-2010, 11:49 AM
Re: Blower Switch Wiring
you're switching output jack ground...seems wrong
What you want to do is cut the ground of tone cap to render it out of the circuit. 0.022uF cap's other end shouldn't go to the back of the pot but to the switch. When switch is ON, connection between ground and cap should be broken. To kill volume switch, you'd have to connect volume lug that's normally grounded to the same lug on your blower switch where that cap is connected.
bancika is offline
post #3 of 5 (permalink) Old 11-11-2010, 02:39 AM
Reviews: 120
You need a DPDT switch for it. I found a Premier Guitar article online about it. I'll post it when I get to my desktop pc. I'm going to do a DIY article for my blog soon.
LonePhantom is offline
post #4 of 5 (permalink) Old 11-11-2010, 04:58 AM
Without the DPDT switch you will still leave the volume and tone pot loading the circuit.
You need to disconnect the jack signal wire from the volume pot with one set of poles and disconnect the bridge pickup from the PU switch with the other. When these two connections are broken, i.e. the switch is thrown, these two should be connected together, pickup straight to output no loading.
The added complication is in your circuit when the bridge pickup is tapped it will still be tapped when the blower is activated.
Hope this helps!
Jim
Vim Fuego is offline
post #5 of 5 (permalink) Old 11-11-2010, 05:21 AM
Reviews: 120
This might help you with working out what you need to do:
http://www.premierguitar.com/Magazin...aster_Mod.aspx
blower , guthrie govan , switch
V7 and V8 wiring with 3 way switch? ManicSubsidal Pickups & wiring 4 03-29-2009 03:17 AM
help with 3 way switch wiring mackself Pickups & wiring 4 04-23-2008 03:43 PM
EMG H-S-H WIRING / 5 way switch jasonmke Pickups & wiring 2 09-28-2007 09:09 PM
Hum-Hum, 3-way switch + Coil Tap Switch Wiring TAorama Pickups & wiring 1 06-19-2005 01:12 PM
PRS blower push pull????? aerocol Tech: Setup, Repairs and Mods 10 05-25-2003 09:05 PM
