Breed neck / bridge difference in bridge position - Jemsite
post #1 of 3 (permalink) Old 05-25-2005, 05:42 AM Thread Starter
Can anyone compare both Breed pickups in bridge position?
I by mistake got neck version for bridge position in mahogany guitar with PAF Pro in the neck.
It sounds very much like PAF Pro , a bit louder, aggresive and with more bass.
On the other hand, PAF Pro in the neck is also bassy and as loud as Breed.
So combination PAF Pro/Breed neck is very decent soundwise, only one thing you hear very little difference when switching from neck to bridge position.
I am not sure should I be replacing this pickup with bridge version or not?
Marin
marino is offline
post #2 of 3 (permalink) Old 05-25-2005, 07:02 PM
Re: Breed neck / bridge difference in bridge position
if it sounds good leave it in! I think it has a little less mids and a little less bass due to the fact that those are more prominent in the neck area. But like I said, if it sounds good then leave it in.
RSVampire is offline
post #3 of 3 (permalink) Old 05-25-2005, 09:43 PM
Dimarzio recommends the Breed neck in the bridge pos with the PAF Joe in the neck. So u shld be alrite there.
lloop9 is offline
bridge position , paf joe , paf pro
WHat happens when you put a bridge pickup in the neck position? bdk Gear, Equipment, Recording & Off Topic 16 02-10-2017 04:02 PM
neck pu in bridge position: any issue? higure Pickups & wiring 5 10-20-2012 08:03 AM
D-Activator neck, in UV bridge position Algiman Pickups & wiring 7 09-23-2010 05:58 PM
DC resistance vs voltage, and difference bewteen neck and bridge position pickups LowYaw Pickups & wiring 4 12-15-2008 11:45 AM
an evo Neck in the bridge position??? simonargento All Other Guitars (including Prestige) 0 05-17-2004 12:48 PM
