Breeds: Tinny and Low output - Jemsite
post #1 of 5 (permalink) Old 04-16-2005, 01:40 PM Thread Starter
Hi All,
The breeds on my DBK have a very low output and sound tinny. Going through some of the posts here, I figured it's probably due to a pickup connected out-of-phase.
In an attempt to correct this, I checked out the wiring diagrams on Ibanez's site. However the wiring diagram is very different from the one on my DBK.
Ibanez's wiring diagram uses a VLX91 and an OTAX for the pickup switching system. My guitar has a single VLX53 5-way switch.
If any of you have a wiring diagram for the VLX53, please let me know (or if you have any other suggestions to fix the low output)
Thanks
Sudhir
ksudhir78 is offline
post #2 of 5 (permalink) Old 04-16-2005, 01:46 PM Thread Starter
Re: Breeds: Tinny and Low output
Just some more info on this...
The neck pick up sounds OK (not tinny, but still a low volume). The bridge pick has less than half the output of the neck pickup and is very tinny. The in-between positions have a moderate output (as expected)...
post #3 of 5 (permalink) Old 04-16-2005, 01:49 PM
Have you tried adjsuting the height?
markg5150 is offline
post #4 of 5 (permalink) Old 04-16-2005, 02:14 PM Thread Starter
Yes, I tried adjusting the pickup height....not too much of a difference, though
Sudhir
post #5 of 5 (permalink) Old 04-18-2005, 08:06 PM
As stated in the Dimarzio "4 Conductor" manual (full thing can be found on their website)
"To reverse the phase of the Dimarzio pickup, reverse the red and green wires. Solder the RED wire to ground, and the GREEN wire to hot."
Your only going to want to do this with one of you pickups and it doesn't matter which you choose. Hope it works out for you.
Tool is offline
dimarzio pickup , neck pickup , pickup height , pickup switch , pickup switching , wiring diagram
Evolution pickup sound extremely tinny? Flimbo Pickups & wiring 4 02-25-2011 07:20 AM
Neck Evolution pickup sounds weak and tinny nighttraveler Pickups & wiring 9 07-25-2009 10:05 AM
'03 7VWH squealy tinny sound ???? JEMsnUVs4j Pickups & wiring 5 02-02-2009 10:48 PM
Breeds? Smitty Gear, Equipment, Recording & Off Topic 13 09-19-2007 06:34 PM
Humbucker sounds tinny in split mode -- help? SBlack Pickups & wiring 7 11-16-2003 09:08 PM
