Coil split with HSH??? - Jemsite
post #1 of 6 (permalink) Old 07-18-2012, 05:01 PM Thread Starter
Well I'm thinking in a mod for my RG370 (HSH).
Using the standar 5way switch, Basically I want this configuration:
(using coil split)
1 Bridge (outer coil)
2 Bridge (inner or outer coil?) + Middle
3 Middle
4 Neck (inner or outer coil?) + Middle
5 Neck (outer coil)
which is like a Strat S-S-S configuration
I'm not sure if in this case I'll have outer or inner coil in position 2 and 4. Please explain
(without coil split) the classical Ibanez one that is now on my guitar.
1 Bridge humbucker
2 Bridge (inner coil) + Middle
3 Middle
4 Neck (inner coil) + Middle
5 Neck humbucker
Is it possible to do this? Can you provide me diagram? What kind of pot or switch I have to buy?
I was thinking about a push/pull tone pot but I'm note sure.
Thank you
Jackblack9 is offline
post #2 of 6 (permalink) Old 07-28-2012, 03:27 AM
Re: Coil split with HSH???
I'm sure its possible but would take an experienced tech to get it right with the coil splitting, but may I ask with a 5 position switch and 4 other available (single-coil) configurations why would you possibly want to give up the bridge humbucker?
Roadster is offline
post #3 of 6 (permalink) Old 07-28-2012, 03:52 AM
Reviews: 98
All of the info you need is in this sticky thread:
http://www.jemsite.com/forums/f35/an...ad-110579.html
Your desired configuration is not possible with the stock switch--you need a multipole switch.
AlaskaBat is offline
post #4 of 6 (permalink) Old 07-28-2012, 12:16 PM
RGTFanatic's Avatar
I would add a mini toggle to split the hums. That way you can have them as hums or singles in addition to the stock configuration.
RGTFanatic is offline
post #5 of 6 (permalink) Old 07-31-2012, 04:25 PM
Reviews: 98
Yep!
A push/pull pot in the tone pot wired correctly will do the trick
post #6 of 6 (permalink) Old 07-31-2012, 07:42 PM
I did the exact same question some years ago, and djohns74 provided a wiring diagram
But anyway, hope you find it useful
http://www.jemsite.com/forums/f35/co...hsh-94641.html
I made the mod but I didn't like it very much, I don't like the sound of single coils in the bridge and there was a drop in volume, and just sounded to thin... so I went with a series-parallel switching just for the neck pickup
rub_800 is offline
coil split humbucker
Coil split with HSH??? rub_800 Pickups & wiring 12 03-31-2011 12:30 AM
Coil Split a K-7 Vaibanez Pickups & wiring 1 04-08-2009 09:56 AM
Coil split for Paf Pro and Fred eg Pickups & wiring 4 10-16-2007 03:49 PM
Evo 2...coil split Rayniac Pickups & wiring 0 11-28-2006 09:43 AM
JPM with Coil Split? phienix Pickups & wiring 0 09-03-2004 12:58 PM
