Coil Split Question - Jemsite
post #1 of 4 (permalink) Old 04-24-2019, 07:45 AM Thread Starter
Coil Split Question
I got an Ibanez RG8MS. Amazing guitar, totally blown away.
It has a fairly complicated switching system you can see in the attachment.
I am wondering if I could add a push/pull pot to make a coil split option as well?
It may be a stupid question and sorry if that's the case, I am clueless on wiring.
A pot recommendation would be appreciated also.
Also, the little truss rod adjustment thingy was broken, the little wheel.
Anyone knows where I could buy a replacement one by any chance?
Love!
Dragisa
Dragisa Boca is offline
post #2 of 4 (permalink) Old 04-24-2019, 04:15 PM
Re: Coil Split Question
what positions are you trying to make single coil ? cts pots are nice but they are a larger diameter hole so to use them you'd have to drill/ream the current holes larger. Bourns pots are good too, and I believe they come with the same diameter hole as the Korean/Chinese pots.
j.arledge is offline
post #3 of 4 (permalink) Old 04-25-2019, 02:51 AM Thread Starter
I would like to be able to play single coil in both neck and bridge positions. Can that be done with one pot or do I need two?
I didn't know about the diameter differences, thank you for pointing that out.
post #4 of 4 (permalink) Old 04-25-2019, 05:24 PM
yes it is possible, you'd need a new 5 way switch. You'd also need to nail down what exact configuration you want the switch to be. Another issue is going to be if your pickups are 4 conductor pickups. The neck probably is because there is a parallel option in the current switch, but the bridge pickup may only be 2 conductor.
i think the first one would be the most effective from a tone stand point.
8string , ibanez
converting humbucker to split only one coil ubertwerp Pickups & wiring 3 11-26-2006 01:53 AM
2 HBs, 2 vols, push-pull coil split - Wiring Help Needed! Mr Orange Tech: Setup, Repairs and Mods 7 03-22-2006 12:16 PM
Anybody has Jem7vwh with coil split to comment? JFT Pickups & wiring 6 05-20-2005 02:53 PM
JPM with Coil Split? phienix Pickups & wiring 0 09-03-2004 01:58 PM
Fat Strat with coil split switch? cypher2198 Pickups & wiring 1 05-30-2003 11:50 AM
