Color question - Jemsite
post #1 of 10 (permalink) Old 09-08-2003, 03:38 PM Thread Starter
Color question
OK, I've got two leads poking through to the control cavity. One's a Duncan PG, and the other is a Dimarzio Fred. I have no idea which wire came from which pickup, and it would be very difficult to find out. The differences between them: one has a dark, forest green green wire, and the other has a lighter, almost kelly-green wire.
I need to know which one's which, and if I can't, I'm kinda up the creek sans-paddle. Any help would be appreciated. Thanks.
Reaper is offline
post #2 of 10 (permalink) Old 09-09-2003, 12:52 AM
ScottB's Avatar
Try pulling one of the leads, back and forth, very lightly, and see if one of the pickups pivots backward a bit. This was the method I used when replacing the 3 way switch on a Les Paul once.
ScottB is offline
post #3 of 10 (permalink) Old 09-09-2003, 05:41 PM Thread Starter
tried it... neither of them move.
Reaper is offline
post #4 of 10 (permalink) Old 09-10-2003, 12:08 AM
ScottB's Avatar
Do you have access to a ohm/volt multimeter?
If you do, set it to read continuity. Touch one probe to one of the mounting screws on a pickup. Touch the other probe to the ground wire of either set of leads. Watch for the meter to react or listen for the continuity tone and you've found your match.
This will work assuming your pickups aren't mounted together on a metal pickguard, and that both sets of leads are insulated in plastic, not the wire braided type covering on PAFs.
ScottB is offline
post #5 of 10 (permalink) Old 09-10-2003, 08:31 AM
Are the pickups mounted on a pickguard or are they mounted in rings?
Is there some reason why you can't just remove your strings and lift one of the pickups out to see which wire moves?
darren wilson is offline
post #6 of 10 (permalink) Old 09-10-2003, 09:11 AM
Just wire em up,make a note of how the guitar sounds,if the neck sounds trebly reverse the pickups ;-)
If you really need to leave the strings on,or not move the pickups away from the guitar,thats what i would do (my custom Evo's are not marked to differentiate which is neck/bridge,so i had to do it)
HTH
Rob
Jem7RB MK is offline
post #7 of 10 (permalink) Old 09-10-2003, 03:11 PM Thread Starter
I'll give that a shot... will the "ears" work (the part that's threaded)?
Anyway, they're direct-mounted with nails. Which is why neither moves, and why I can't just pull 'em out.
Reaper is offline
post #8 of 10 (permalink) Old 09-10-2003, 04:16 PM
jim777's Avatar
Wow. A Custom Shop one off, eh?
jim
jim777 is offline
post #9 of 10 (permalink) Old 09-10-2003, 05:05 PM
post #10 of 10 (permalink) Old 09-10-2003, 06:24 PM Thread Starter
Sweet. It worked. Thanks ScreamJem.
And yes, Jim, it's a custom shop one-off straight out of my basement.
Reaper is offline
custom shop , les paul
Pickups and Color Question for RG570 millhouse Pickups & wiring 15 09-02-2011 01:50 PM
Swirl question - color wont stay in position nafigator Tech: Setup, Repairs and Mods 0 07-03-2009 04:46 AM
UVMC color question eelblack2 Vendors, Auction & Reseller Talk 57 10-06-2006 02:37 PM
RG1570 color question Heka All Other Guitars (including Prestige) 5 03-23-2005 01:37 PM
Color question on refinishing a 520... NickFlyMan Tech: Setup, Repairs and Mods 6 12-18-2003 02:47 PM
