Crazy for the D-activator! - Jemsite
post #1 of 1 (permalink) Old 11-15-2013, 04:50 PM Thread Starter
Just installed a d-activator f-spaced bridge in my RG331 following this scheme:
http://www.dimarzio.com/sites/defaul...7_DiMarzio.pdf
works perfect!
I transferred the V7 that I was testing for bridge in the neck leaving it wired as before and installed the activator as intended for the neck pickup in series-parallel-split (now the switch positions are inverted for neck-bridge)
Don't trust ibanez pickup color codes, is not red, white, black, like dimarzio except the green that is blue.
I found out that the color of wires of the inf pickups can be totally casual, every color can be anything, red was connect to back of the pot, crazy!
Now I think that the V7 sounds like poo and was influencing bad my playing, by the way D-activator don't seem very much louder than V7, I have to lower a little V7 in the neck to balance sound, maybe I was expecting too much from the declared 470mv of output and put the activator too much low?!?
Now I see is not that strong magnetic field is supposed to have the activator X or X2n!
poles line up well on 1-2-3 strings, than starts to be less aligned from 4-5 and 6 is on the outer border, dimarzio should make their f-spaced a bit larger!
Josephmetal is offline
331 , d-activator , dimarzio , ibanez , pickup
WTB: DiMarzio D-Activator Set (Not D-Activator X Set) xSoDopeImHeroinx Classified Ads: Guitars and Gear 0 08-03-2011 05:43 AM
D-Activator sth550 Pickups & wiring 11 03-02-2011 08:53 AM
D-Activator 7's D.M.RG7620 All Other Guitars (including Prestige) 7 12-14-2010 11:39 PM
D Activator-X / X2N Altitudes911 Pickups & wiring 14 05-28-2008 12:30 AM
D Activator-X 70Seven Pickups & wiring 9 02-20-2008 07:06 PM
