Did I wire my pick up right? - Jemsite
post #1 of 6 (permalink) Old 07-31-2003, 05:38 AM Thread Starter
Hi,
I have an Ibanez S540 -88 and I decided to change the bridge pick up. I bought a SD TB-4. The original pick up (IBZ F2) had four conductor wires (red, white, black and green and ground of course) and the SD had the exactly same colored 4 wires so I just soldered the SDīs red to the place of IBZīs red, SDīs white to the place of IBZīs white and so on...
I was just wondering if it went right? And if it didnīt, which wires do I have to change?
/Heikki Lindström, Finland
Heka is offline
post #2 of 6 (permalink) Old 07-31-2003, 12:55 PM
This is from Duncan's website FAQ.
"All Seymour Duncan humbuckers with four-conductor hookup wires incorporate a standard wire color code.
Green = beginning of adjustable coil
Red = finish of adjustable coil
Black = beginning of stud coil
White = finish of stud coil
For standard series humbucking operation on a 4-Conductor wired humbucker the White & Red wires are soldered together and taped; Green is ground and Black is Hot Output. The bare wire is also grounded."
jeff l is offline
post #3 of 6 (permalink) Old 07-31-2003, 07:53 PM
easy answer: swap the red and black wire. if the output is funky and does some weird out of phase sound when on position 4, reverse the black and green wires.
rich
rty13ibz98 is offline
post #4 of 6 (permalink) Old 08-08-2003, 05:10 PM Thread Starter
rich
Thanks Rich! I swapped the red and black wires. I hope itīs right now =). To make it sure, I drew a picture of the wiring hoping that you guys could take a look at it. Can someone confirm it is right by judging from the picture (click the link for the picture).
http://www.angelfire.com/bug/kaavio/
Heka is offline
post #5 of 6 (permalink) Old 08-09-2003, 08:58 AM
Re: Did I wire my pick up right?
the F2 was made by DiMarzio, and uses their wire color conventions. annoyingly, Duncan and other manufacturers use the same colors but the wires go to different places in the pickup.
hard answer: use a conversion chart that shows DiMarzio and Duncan wire colors to show you what color Duncan wire should go to where the red DiMarzio wire was. pickup wire color conversion chart: http://www.stewmac.com/wiring101/hum...g_options.html
post #6 of 6 (permalink) Old 08-09-2003, 11:20 AM Thread Starter
Thanks man! If itīs true that F2īs wires are colored to match DiMarzioīs colors, then it was just to do what Rich adviced me to do: to swap the black and red wires and in that case it is now connected correctly (check my previous post for the link for the current wiring diagram). Anyone still want to confuse me some more ?
Heka is offline
seymour duncan , seymour duncan humbuckers , wiring diagram
Is there a specific type of wire needed to wire a guitar? IBNZ_RG Pickups & wiring 6 04-18-2010 01:48 AM
Pick up Wire Colors**** psychoticsnoman Pickups & wiring 1 02-02-2008 05:28 AM
Rewiring Job: What wire is good wire? Gex Tech: Setup, Repairs and Mods 3 06-11-2005 01:01 PM
How to wire new pick up? Heka Pickups & wiring 3 10-28-2003 06:21 AM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an floydJ Tech: Setup, Repairs and Mods 3 08-07-2001 12:59 PM
