Dimarzio Chopper (Neck), Dimarzio Fred (Bridge) 1 Vol (coil tap), No Tone, No Switch - Jemsite
post #1 of 3 (permalink) Old 10-14-2016, 04:06 PM Thread Starter
Hi All,
My configuration is:
Neck: Dimarzio Chopper Stacked Pickup
Bridge: Dimarzio Fred
Both are 4 wire types.
I don't want a switch and no Tone Pot either.
I do have a Volume Pot that has a push-pull.
Now, what I'm looking to do:
Use the Push-Pull to switch on Neck and Bridge separately (effectively use a switch) so
Push = Neck Pickup
Pull = Bridge Pickup
Any wiring suggestions? I have looked at the George Lynch config over on SD but that uses a single coil instead of stacked - would it still work? Here's a link http://www.mylespaul.com/forums/showthread.php?t=358043
xperiate is offline
post #2 of 3 (permalink) Old 10-15-2016, 02:14 AM
Re: Dimarzio Chopper (Neck), Dimarzio Fred (Bridge) 1 Vol (coil tap), No Tone, No Swi
It should work as you will connect two wires and ground wire to switch. But there should be four wires and ground wire on pickup giving you choice of serial, parallel or true single coil connection.
peromucho7 is offline
post #3 of 3 (permalink) Old 10-15-2016, 07:47 AM
here this should work
http://guitarwiring.blogspot.com/201...-selector.html
LACS-plus is offline
dimarzio , js2400 , wiring
FT-Dimarzio TZ Humbucker & Dimarzio Chopper Single Coil! camjam71 Classified Ads: Guitars and Gear 1 09-28-2013 09:53 AM
Dimarzio middle single coil with Dimarzio breed neck and bridge csar_gal All Other Guitars (including Prestige) 13 12-04-2012 09:55 AM
WTB: Blue DiMarzio vol/tone knobs and switch tip Dr.StrangeNote Classified Ads: Guitars and Gear 5 05-03-2010 09:51 PM
HH, 3 Way Switch, 1 Vol, 1 Tone w/ Push Pull Coil Tap Zgicc Pickups & wiring 0 05-12-2009 04:37 AM
DIMARZIO EVOLUTION COIL TAP TONE puppiesonacid Pickups & wiring 2 06-01-2003 06:14 AM
