dimarzio clarity with volume rolled down - Jemsite
post #1 of 9 (permalink) Old 09-02-2007, 06:14 PM Thread Starter
I was at GC yesterday playing a JS1000BK just to get an idea of the differences of pickups/amps etc. I noticed that (maybe the amp but dont think so) with the volume rolled down the pickups seems to be less clear than my stock v7/s1/v8 config. Now realizing that those ibanez pickups are very thin sounding (feel free to argue this), I guess it would make a little sense they would sound clearer with the volume down. Whats your opinion on this guys? And what pickups are clearer than others? Thanks
Mister CCJ is offline
post #2 of 9 (permalink) Old 09-03-2007, 04:20 AM
Re: dimarzio clarity with volume rolled down
Sounds like you got an some sort of RG?
These all have high pass filters on the volume pot... the JS1000 has a high pass filter but it needs to be activated by pulling up the volume pot.
so if you rolled down the volume on a JS it would get muddier then if you rolled down the volume on yor RG... unless you pulled up the volume pot first
so congrats youve just accidentally identified the difference a high pass filter can make ... there must be about 500-600 topics titled "my high pass filter doesnt work" or "I cant hear any difference with the high pass engaged" etc etc
Devo is offline
post #3 of 9 (permalink) Old 09-03-2007, 04:27 AM
eg
Is that really true? I thought they were actually the same pots, just that the JS has an additional high pass filter to cut out the lows if it is pulled out?
eg is offline
post #4 of 9 (permalink) Old 09-03-2007, 06:36 AM
Yes this is true... Nearly all modern Ibanez have a high pass filters hard wired to their volume pot... the JS is the only one where you can choose to disable this ... have a look through the diagrams here... the "331" cap on the volume pot in each diagram is a high pass filter... only the JS has this on a push pull....
http://www.ibanez.com/support/wiringdiagrams.aspx
all pots of the same resistance value and same taper are the same ...
The easiest way to describe it is to try and not think of the signal comming from your pickup as one signal, but as hundreds of thousands of signals all at different frequencies travelling all at the same time.
These signals react differently when they hit the 500k ohm barrier between them and the gound that the pot creats... The high frequencies find it much easier to get though this barrier then the low frequencies and hence the effect that you get is that you lose the high frequency .. and as you lower the resistance and the jump to ground gets easier, more high fequencies escape so that the sound gets muddier and muddier..
When you bypass the pot with a capacitor for all intents and purposes you reverse this effect... what happens is that capacitor acts as a road block for low frequency sounds but lets high frequency sound pass through relativly easy... When the pot is at full value it makes little difference as its easy for all the differnet frequency sounds to escape out to your amp... As you turn the pot down and the resistance drops some of the frequencies start escaping to the ground but the high frequencies find it easier to go through the cap so continue to escape to your amp.. wuntil finally its easier for them to go to ground then go through the cap and your sound dissappears.
this is an overly simplified description whose attempt is to describe the effect rather than the means
Devo is offline
post #5 of 9 (permalink) Old 09-03-2007, 07:29 AM
Give the guy a medal. That's as good a description of "high pass" as one could get.
Ibateur is offline
post #6 of 9 (permalink) Old 09-03-2007, 08:14 AM Thread Starter
haha wow I had forgotten about that on the JS. Yea its a RG btw. Awesome thanks guys.
post #7 of 9 (permalink) Old 09-03-2007, 10:53 PM
eg
Good explanation. So the JS has the high pass filter disabled when the pot is pushed down and enabled when the pot is pulled out.
That would explain why you say that the JS is muddier compared with a typical RG when the volume rolled down with the pot pushed down. The high pass filter is not enabled.
An RG would have the high-pass filter enabled all the time.
What are the advantages of doing that btw?
eg is offline
post #8 of 9 (permalink) Old 09-04-2007, 04:52 AM
the main advantage is the sound... which is entirely subjective but I much prefer the sound of a volume pot with a high pass filter as the tone stays pretty much the same as you roll the volume back... and if you want to lose some treble you can use the tone pot to achieve the same effect as a volume pot without a high pass
the second big advantage is not having a push pull that get in the way of your picking and the whammy bar... on my previous 2 JS I have hard wired the high pass filter (but then returned ithem factory spec when they were sold)
the third advangtage is that having it hard wired meas less cable, less parts and less solder for you signal to go though before it leaves the guitar.
Devo is offline
post #9 of 9 (permalink) Old 10-02-2007, 03:16 AM
eg
So in essense, a JS with the high-pass filter engaged will sound like any ordinary RG with the volume rolled down.
eg is offline
high pass filter , ibanez pickups
WTB: Dimarzio pickups in PINK !!! dookie_cookiez Classified Ads: Guitars and Gear 6 05-07-2007 07:33 PM
WTD: Custom/59 Hybrid, 59 neck, or Dimarzio Paf Pro/VHPaf and others Pickups deenkarim Classified Ads: Guitars and Gear 0 02-19-2007 08:40 PM
still noise in my dimarzio -Rhaab Pickups & wiring 10 10-24-2006 01:58 PM
FS - Dimarzio Air Zone, Jem PAF Pro, and RG Pickguards gpenguins Classified Ads: Guitars and Gear 0 10-23-2006 06:51 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 07:06 AM
