Dimarzio Evolution on an Ibanez s320 5 way wiring - Jemsite
post #1 of 6 (permalink) Old 02-14-2008, 01:41 AM Thread Starter
Hello,
I was wondering if anyone could help me out with some wiring advice. I'm trying to mount diamrzio evolution dp158 and dp159 humbuckers on an Ibanez s320 guitar http://www.ibanez.com/eg/guitar.aspx?m=S320 .
Problem is, it has a 5 way switch, and the infinity coils use a different color code than dimarzio. Since i have only done standard humbucker wiring before, i am a bit confused as to how i should solder these wires.
Does anyone have a wiring diagram showing how to connect evos to a 5 way switch? If not, could anyone please explain in words what wires go where... i'm a little desperate...
Thank you!
efdi is offline
post #2 of 6 (permalink) Old 02-14-2008, 07:02 PM
Re: Dimarzio Evolution on an Ibanez s320 5 way wiring
This may help. Assuming the old pickups had a red, a white and a shield. The DiMarzio shows which wires to solder together for standard operation(I think its black and white), attach the DiMarzio red where the original red went, attach the black/white combo where the original white went and green and shield to ground. I'm not positive on this. You could also just replace the switch with a 3-way or get one of the super-switches from stewmac.com (which should come with wiring diagrams).
albee1952 is offline
post #3 of 6 (permalink) Old 02-15-2008, 05:06 AM Thread Starter
Thx m8. I used a wiring diagram for a rg1527 and i think i've got it all running.
For neck: green and bare were ground, and white was where the original infinity blue went. black and red went where the original infinity black and red were.
For bridge: same as above except black and white were soldered together.
Everything sounds ok and the positions seem in order. Thank god that's over with.
efdi is offline
post #4 of 6 (permalink) Old 10-30-2008, 08:54 AM
Edit...
S-man is offline
post #5 of 6 (permalink) Old 10-30-2008, 09:07 AM
once you figure out what the hot is your home free. i think its white & red.....
callen3615 is offline
post #6 of 6 (permalink) Old 10-30-2008, 09:40 AM
Sorry I replied to the wrong thread... this thread is old.
But here is the diagram anyway....
S-man is offline
wiring diagram
Ibanez to DiMarzio pickup conversion Chromex Pickups & wiring 5 08-04-2007 01:24 PM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez] TheJazzTerminator All Other Guitars (including Prestige) 224 08-18-2006 06:48 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 04:59 PM
Ibanez installed DiMarzio PUPs - Are they the same as over t scarello Ibanez JEM, UV, JS & Other Signature Models 2 02-28-2002 08:42 AM
