DiMarzio - Ibanez Wires - Jemsite
post #1 of 7 (permalink) Old 11-03-2004, 11:16 AM Thread Starter
i want to upgrade the bridge pickup of my sz520 with a dimarzio super distortion.
can anybody tell me which color of the ibanez wires correspond to the color o f the wires of the dimarzio pickup so i know on which pin i have to solder the wires of the new PU?
CactusJack is offline
post #2 of 7 (permalink) Old 11-03-2004, 12:38 PM
From looking at the diagram for the SZ520..
http://www.ibanez.com/wiring/wire.as...&w=SZ520QM
you should be able to wire it just as it currently wired...if it sounds out of phase switch the green and red wires...
SpidaWeb is offline
post #3 of 7 (permalink) Old 11-22-2004, 04:03 PM
Doesn't work. I'm trying to install two Dimarzio's in my SZ320MH and it's not working out so far. First I connected the Dimarzio's just as the originals were. Sound was extremely thin. Just barely there. So I switched the green and red wires and now it's better but still very thin and on each humbucker one side is stronger than the other. If you touch a metal screwdriver to each side of the humbucker you can hear the difference. Anyway I will figure it out but it's not as simple as just following the original wiring.
It may end up being easier to completely re-wire the guitar.
Rotti is offline
post #4 of 7 (permalink) Old 11-22-2004, 05:02 PM
Okay so it is prety much like the original wiring except...
With the Dimarzio's both white and black wires go together. With the original pickups one had black and white together and another had red and green together.
On each pickup the green goes to ground and the reds to the volume pots.
Everything is in phase and sounds good.
Rotti is offline
post #5 of 7 (permalink) Old 11-24-2004, 09:09 AM Thread Starter
got my new super distortion today for my precious SZ520.
are the two coils exactly the same? i canīt decide in which direction i should install the humbucker. because the two coils look quite the same i donīt know if the one coil should face the bridge or the other....?
do you have to solder black and white toghether even if you want to keep the original switching?
post #6 of 7 (permalink) Old 11-24-2004, 12:24 PM
The black and white wires go togther. Even with the original wiring there is two wires on each pickup that go togther on the 3 way switch. Make those the black and white from your Dimarzio. Then the green goes to ground and red to volume pot.
I'm not sure how you tell which way to put the pickup if the two sides look the same. I would think the wires come from the correct side of the pickup to line up with the routes in the body.
You are going to notice a MAJOR difference.
Rotti is offline
post #7 of 7 (permalink) Old 11-29-2004, 09:51 PM
The orientation of the pickup will not matter in normal series wiring. If you plan on splitting the pickup at anytime, then the location of the coil that is on will make a slight difference. However, to me this would be your own preference. Personally, the factor that affects which way i turn the pickup is which side the wire comes out, so that wiring is easier.
The stock pickups on my rg550 (v1 + v2) had only 3 wires as opposed to dimarzio's 5--a hot connection (on the p/u selector) which was red, and then a black and a white, one to ground and one to the p/u selector for tapping the coil. If you are doing a clean swap, wire dimarzio red to the old hot connection, solder black and white together and then to the other spot on the selector switch, and then green and bare to ground. As already stated, red and green can be switched to reverse the phase.
Champagne Mist is offline
bridge pickup , dimarzio pickup , dimarzio super distortion , super distortion , volume pots
inf 3 & 4 with 4 wires poolguytim Pickups & wiring 0 12-08-2012 12:12 PM
Wires Devon8822 Pickups & wiring 4 01-07-2010 11:44 PM
Duncan Seymour and DiMarzio wires color Orochimaru Pickups & wiring 10 07-28-2009 02:50 AM
EVO X2N wires? Dimarzio989 Pickups & wiring 7 08-07-2006 09:28 PM
emg wires JimmyW Pickups & wiring 2 05-11-2004 11:29 PM
