Dimarzio Pickup Orientation - Jemsite
post #1 of 28 (permalink) Old 03-29-2014, 03:52 PM Thread Starter
I'm confused about the orientation of Dimarzios and I cannot find a straightforward answer anywhere on the web. I know Dimarzio's FAQ states that the physical orientation of the pickup has no "right or wrong direction" and that it is your "preference" , but I seriously would like a more straightforward answer because both directions sound good to me for my Evo2, so I'd rather just pick the orientation that it was designed for (it's some weird OCD-like thing too where it just bothers me that I don't know).
My Dimarzio Evo2 and Breed have adjustable coils on both coils so I can''t judge based on that. I can judge only on the cable exit on the back of the pickup. And both pickups do sound different when flipped around. Please, for the love of god, can someone give me a straightforward answer. Does the cable exit of a bridge pickup face the bridge or headstock???? This annoys me so much that I'm definitely going to buy Seymour Duncans next time since I know which direction they're supposed to go based on the name (I'm really sorry dimarzio)
AttackConquer is offline
post #2 of 28 (permalink) Old 03-29-2014, 05:03 PM
Reviews: 120
Re: Dimarzio Pickup Orientation
Seriously, you're getting that wound up about this so much? Just install them the same way you would the Duncans, problem solved.
LonePhantom is offline
post #3 of 28 (permalink) Old 03-29-2014, 05:30 PM
I always put pickups in with the wires coming out of the bottom right corner no matter what. I thought that's the way all pickups are designed, wires come out closest to the controls. I have never, in my 25 years of playing, opened up a guitar and seen the cables any other way.
GUITARMAGEDDON is offline
post #4 of 28 (permalink) Old 03-29-2014, 05:40 PM
I always install the bridge this way, but I will sometimes flip neck pickups so the poles are on the side I want or if it's a zebra so the colors are going the way I want them too... The change in sound is usually so slight it doesn't really matter to me on the neck pickup...
Swirltop is offline
post #5 of 28 (permalink) Old 03-29-2014, 05:40 PM
RGTFanatic's Avatar
You already have the straight forward answer right from DiMarzio. Both directions are correct and the way they are designed to be used.
You say both directions sound different. The direction that sounds better to you is the definitively correct direction for you and your guitar.
Seriously, does it matter if the peanut butter is on top of the jelly or below it??
DiMarzio gave you a pickup with tonal options. It's like getting two pickups in one box. pick the one you like most and go with it.
RGTFanatic is offline
post #6 of 28 (permalink) Old 03-29-2014, 06:32 PM
CosmicDebris's Avatar
Yes, it does. Jelly on the bottom piece of bread so gravity keeps it from falling off when you put the two pieces together.
CosmicDebris is offline
post #7 of 28 (permalink) Old 03-30-2014, 04:25 AM
Jems and H-S-H RGs with Dimarzio's stock have the neck pickup rotated from the factory.
Breeds don't have asymmetrical coils, so really it doesn't matter unless you're coil-tapping and combining with other pickups.
toshiro is offline
post #8 of 28 (permalink) Old 03-30-2014, 06:26 AM
Dimarzio told me that some of there pickups have the same coils on both sides so it doesn't matter which way you install them.
Other pickups they offer like the Crunch Lab have different coils on each side.
For example, if you flip a CL you'll get two different tones.
If you flip an EVO you won't.
The other factor is coil splitting like toshiro mentioned.
H-S-H configurations with coil splitting want the coil closest to the single coil to be on in the humbuckers in positions two and four.
That's why the neck pickup is flipped with the wires coming out towards the bass side of the guitar.
In a two humbucker guitar they wires go towards the treble side of the guitar on both pickups.
sebastian is offline
post #9 of 28 (permalink) Old 03-30-2014, 10:20 AM
I noticed this while going through JS wiring diagrams for a build I'm working on now as well. Both on JS1200 and JS1000 wiring diagrams the neck pickup is labeled "reversed" and the wiring harness comes out from the "wrong" side of the base plate. (I don't own a JS1000, nor JS1200, so I can't verify if they match the wiring diagram physically though)
When I looked for it on Dimarzio FAQ, though, PAF Joe and PAF Pro are not in the list of "slightly different depending on installation orientation" but the list might be of interest to the OP.
kissTheApex is offline
post #10 of 28 (permalink) Old 03-30-2014, 12:43 PM
The neck pickup is reversed so the inside coils are on when tapped...
Swirltop is offline
post #11 of 28 (permalink) Old 03-30-2014, 04:01 PM
If you are really serious about it, there are a couple of ways to check the position. First is to use the coil tap (black and white to ground) and test which coil is still on. You probably want this coil to be towards the middle of the guitar body for both pickups, as it works best on most Ibanez guitars. This is also the way the pickups supposed to be.
Second way is that (at least on my Dimario's) it states which side is F= forward=north on the the pickup bottom plate. This should be forward towards the headstock.
Note that depending on your pickup selection and orientation (bridge, neck) this might get the dual humbucker mode sound different too.
Jouke74 is offline
post #12 of 28 (permalink) Old 03-30-2014, 10:05 PM
the orientation does matter with some pickups. Straight from dimarzio.com
Does it matter which direction I install my pickup?
Most humbuckers are symmetrical and their sound does not change at all when installed backwards. Humbuckers that are not mentioned in this FAQ sound the same when installed in either direction.
Some humbuckers have a distinctly different sound if you turn them around. There is no right or wrong installation direction. The Bluesbucker® is brighter-sounding with the adjustable screw coil toward the bridge. The D Sonic™ and Crunch Lab™ models (6 and 7 string) and the MegaDrive™ are brighter-sounding with the solid bar coil toward the bridge. The Steve’s Special™ and Blaze™ Bridge model are brighter-sounding with the cable exit side toward the bridge.
Some humbuckers have just a slightly different sound if you flip them to the opposite direction. There is no right or wrong orientation, but it’s a matter of preference for such a subtle difference, if you can hear the difference at all. Models that sound slightly brighter with the cable exit toward the bridge include:
Blaze™ Neck
D Activator™ Bridge
D Activator™ Neck
Evo 2™
Evolution® 7
Evolution® Bridge
Evolution® Neck
FRED®
Mo' Joe™
Virtual P-90™
Models that sound slightly brighter with the cable exit toward the neck include:
Air Norton®
Air Norton® 7
Air Zone™
DLX Plus™ Neck
Humbucker from Hell™
LiquiFire™
Norton®
Tone Zone®
Tone Zone® 7
Single-coil size humbuckers with side by side coils have coils that are so close together that reversing the installation direction does not have an audible effect on the sound.
there you go.
The F on the base plate means that the pickup is F-spaced and is not an indication of how it "should" be installed. It simply means that the pickup has a larger space between pole pieces in order accommodate a wider string spacing like that found on some fender and floyd rose equipped guitars.
j.arledge is offline
post #13 of 28 (permalink) Old 03-31-2014, 03:30 AM
Ha cool did not know that, thought F was forward. Anyway it did match for the tone zone
Jouke74 is offline
post #14 of 28 (permalink) Old 04-01-2014, 07:10 AM
aaah.. Now it makes sense... thanks
post #15 of 28 (permalink) Old 04-01-2014, 10:12 AM
RGTFanatic's Avatar
NUFF said........
dimarzio , pickup
Need answers regarding pickup orientation Eskil Pickups & wiring 6 08-28-2013 04:48 PM
Pickup orientation - Turning them around ashbass Tech: Setup, Repairs and Mods 3 05-20-2010 05:19 AM
Pickup Orientation... How Do You Know? rrhea Pickups & wiring 2 04-29-2007 01:55 PM
Evolution Pickup Orientation Fang Pickups & wiring 5 12-06-2006 10:44 PM
Pickup orientation hittman7 Pickups & wiring 3 06-19-2004 09:40 AM
