Direct mount...HELP!!!! - Jemsite
post #1 of 4 (permalink) Old 07-11-2013, 03:52 PM Thread Starter
Hey guys, I checked the forum looking for this but still not quite sure.....
My RGR1570 came with BNP direct mounted to the body. There was foam or weather stripping under them and they were compressed agaisnt it..you could even see the screw marks from under the pup pressed in. I play through an old solid state, but my chugging dies after a second....never any distortion problems when using emgs or dimarzios through basswood. All i could think about was that major tone was lost through the contact of body and pup. Would i be better off getting a new pickguard that i could mount the pups to? Or was something amiss with the mount of the pups? HELP!!!! I REALLY love this guitar and wanna get it straight!!! THANKS A BUNCH!!!!!!!!!!!!!!!!!!
caruso1974 is offline
post #2 of 4 (permalink) Old 07-11-2013, 04:37 PM
Re: Direct mount...HELP!!!!
this should not contribute to tone loss. so you took the pickups out?? did you replace them with something else or just put them back in?
GUITARMAGEDDON is offline
post #3 of 4 (permalink) Old 07-11-2013, 05:00 PM Thread Starter
just took them out. planning on putting cl lf in instead. Had Deactivator x and breeds in 2 of my previous rg's without a problem. distortion was thick and heavy...not quite as good as emgs in mahogany, but acceptable. this really sounded terrible so, im afraid to put em back in...did a lot of research and it seemed EVERYONE preferred the BNP in the bassword, and that it was kinda the WHOLE theory why it was made... Not sure if the foam that was in there was cut right, or too much contact. Forgot to mention there was also a push-pull coil tap that was in. I thought i mightve been wired wrong originally, then took it to my tech who changed the 5 way toggle to a 3 way toggle and moved the coil tap from the tone to the volume position. after 80 bucks.......it sounded EXACTLY as dull as when i first got it!!! Too me, its such a sweet guitar that i wanna get it right...debating taking it to another tech about 45 min from my house to have him dremmel and throw in EMGS... My sons old RG321 with passive EMG's sounds better than my TEAM J CRAFT!!!!! Thats just WRONG!!!! Thanks for any tips!!!
post #4 of 4 (permalink) Old 07-13-2013, 03:09 PM
Sounds like it may be your guitar body and neck. I'll take it off your hands for $50
linthat22 is offline
bnp , mounting
Converting your Ring/guard mount pups to Direct mount RGTFanatic Tech: Setup, Repairs and Mods 77 04-08-2012 06:52 PM
How to direct mount pups hangingmonkey Pickups & wiring 9 02-07-2012 06:15 AM
Direct mount for IBZ/USA F2/F3 DR5Guy Pickups & wiring 1 12-16-2011 08:33 AM
FT: F2 and F4 direct mount finstah Classified Ads: Guitars and Gear 0 01-16-2009 11:10 AM
Direct Mount Pickups Ant1981 Tech: Setup, Repairs and Mods 1 09-15-2006 02:14 PM
