Do I have a 250k in my guitar??? - Jemsite
post #1 of 12 (permalink) Old 01-31-2007, 12:54 PM Thread Starter
I recently had EMGs pulled out of my ESP, and a pair of DiMarzios installed. Since the pots had to be replaced as well and I never told the tech what values to use, I was wondering if a 250k volume could be the cause of the problem I'm having...
My bridge pickup (Steve's Special) sounds like a neck pickup; It is VERY bassy. I have the same pickup in my RG and its MUCH brighter than this. Said ESP is made of Hard Ash to boot so I would imagine it should be even brighter than the RG.
Does this sound like a pot value problem, or is something else possibly wrong here? I know the tone pot is 500k (A buddy of mine just checked it for me), but there are no visible numbers on the Volume pot.
jm1681 is offline
post #2 of 12 (permalink) Old 01-31-2007, 02:00 PM
Re: Do I have a 250k in my guitar???
Is it installed facing a different direction? That can make a difference.
waylay00 is offline
post #3 of 12 (permalink) Old 01-31-2007, 02:29 PM Thread Starter
I thought of that but I haven't taken it out to check.
I do know there is a visible ball of solder on one of the corners of every DiMarzio I've ever seen. When compared to my RG, said ball is in the same place leading me to believe it is oriented the same way.
jm1681 is offline
post #4 of 12 (permalink) Old 08-24-2007, 02:50 PM Thread Starter
Hello again.
The problem persists. The volume is a 500k, so thats out.
The capacitor on the Tone control only has an effect on tone when the knob is moved right? Or IOW, when its all the way up, its bypassed right?
Anyone else have any ideas as to some other possible causes of an exceptionally bass ridden tone?
jm1681 is offline
post #5 of 12 (permalink) Old 08-24-2007, 07:11 PM
Are you sure he didn't wire it in so that the neck pickup is used in the bridge position of the switch?
TommyGuitar is offline
post #6 of 12 (permalink) Old 08-24-2007, 08:10 PM Thread Starter
Gimme some credit.
No its definitely not selecting the neck pickup.
jm1681 is offline
post #7 of 12 (permalink) Old 08-24-2007, 08:30 PM
what tommy said does sound likely, it's an easy mistake.. did you check it by tapping the pup poles with your finger and pushing the strings onto them to get the loud pop sound when selected to see which ones are on?..
and another possibility- are you sure it's wired in serial not parallel or something?
Ki swordsman is offline
post #8 of 12 (permalink) Old 08-24-2007, 08:42 PM Thread Starter
Originally Posted by Ki swordsman View Post
...did you check it by tapping the pup poles with your finger and pushing the strings onto them...
Was the first thing I did
...are you sure it's wired in serial not parallel or something?
This I am not sure of, but last I checked, the wiring appears to be typical of series.
jm1681 is offline
post #9 of 12 (permalink) Old 08-24-2007, 08:51 PM
cool, had to cover those bases.. is the RG definitely also 500k? and the RG does have a tone pot or raplacement resistor?
i think it's probably time to check the direction of the pup, i'd go by where the wire comes out not the solder ball..
post #10 of 12 (permalink) Old 08-24-2007, 08:58 PM Thread Starter
RG's controls are stock.
I'll check the direction, but I'm not holding my breath.
I think the problem is between the pickup and the output jack. The switch is an EP1111, and everyone insists it is NOT the problem. For some reason, I'm convinced it is. The guitar does have a bit of ground noise as well.
Could a bad ground cause a shift in overall tone?
jm1681 is offline
post #11 of 12 (permalink) Old 08-25-2007, 01:56 AM
i'm pretty sure it's either grounded or it's not, you don't get a 'bad ground' unless it's just a sketchy connection.
a bit of noise is normal, it's down to the different levels of shielding each guitar has and the different pups and electronic parts.. if you wanted to lower the noise you could shield the cavities more.
does the pup also sound weaker? if so especially, i'd make a good check that it's wired in series for sure.
and are all pups in the guitar bassier? or definitely just that one? if it's just that one, the problem is probably in the switch wiring or the direction, and my guess would be that the wiring is wrong, and when you have the bridge selected it's selecting Bridge+neck or +necksplit or +middle..
post #12 of 12 (permalink) Old 08-25-2007, 04:19 PM Thread Starter
I'll double check it in a bit.
It does sound weak, hopefully that is the problem.
jm1681 is offline
bridge pickup , bridge position , neck pickup
Funny guitar article Dino All Other Guitars (including Prestige) 40 05-11-2007 08:24 PM
Guitar Player, Guitar World Back Issues (Satch & Vai) jippy Classified Ads: Guitars and Gear 2 12-24-2005 12:40 AM
guitar man with nothing but bad attitude Joshka All Other Guitars (including Prestige) 0 02-25-2004 09:58 AM
Any classical guitar gurus out there? looking for appraisal Willin All Other Guitars (including Prestige) 4 09-17-2002 06:55 PM
tonight's guitar tech and mod work - my RG520Q is a tone MON AJ Love Tech: Setup, Repairs and Mods 4 09-04-2001 07:55 PM
