EMG 3 way switch wiring - HELP!! - Jemsite
post #1 of 9 (permalink) Old 06-26-2013, 05:11 AM Thread Starter
I have the solderless 81/85 and 3 way switch the same as this..
2 and 3, 4 and 5, 6 and 7 are all joined, 1 and 8 independant. I have the same pickups and switch on my other guitar and the neck goes to 2/3, output 4/5, bridge 6/7. 1 and 8 are empty. But they arent the solderless versions.
I have tried copying this set up but it doesn't seem to work. Should it? The instruction shows the following switch, with all 8 pads separate. Do I need one like that or should mine work?
gbh14 is offline
post #2 of 9 (permalink) Old 06-26-2013, 09:51 AM
Reviews: 98
Re: EMG 3 way switch wiring - HELP!!
You might need the other switch.
While similar--the lugs may be allocated differently.
AlaskaBat is offline
post #3 of 9 (permalink) Old 06-26-2013, 10:10 AM Thread Starter
I thought as much, and have ordered the other style but it wont be here until next week.
Is there not another way to wire it though? Surely the switch does the same thing, the lugs may be different, but it ultimately does the same surely? Just different wiring?
gbh14 is offline
post #4 of 9 (permalink) Old 06-28-2013, 01:19 AM
Reviews: 98
Did you look for that diagram on EMG site...for the other switch?
post #5 of 9 (permalink) Old 06-28-2013, 02:34 AM Thread Starter
I looked for a diagram for the switch I have but couldn't find anything.
All sorted now though.. I was using a brand new battery out the pack and turns out it was dead... Haha
gbh14 is offline
post #6 of 9 (permalink) Old 06-28-2013, 09:01 AM
Reviews: 98
Lol--yes, sometimes we look too deep into troubleshooting. Seems the obvious sometimes gets forgotten. ..had that happen before.
post #7 of 9 (permalink) Old 06-28-2013, 09:04 AM Thread Starter
haha it didn't even cross my mind that the battery could be the issue as it was brand new, wrapped in cellophane! I wasted 2 days!!!! I was certain it was the switch!! haha
gbh14 is offline
post #8 of 9 (permalink) Old 07-04-2013, 12:12 AM
When I installed EMG's in an RG 7 I had problems with the switch too. My solution? I found one of the EMG solderless selector switches. It takes the place of the buss controller that is normally used but it also requires a 9 volt battery.
RLH_1976 is offline
post #9 of 9 (permalink) Old 07-04-2013, 12:59 AM Thread Starter
Yeh I did look at that but refused to pay 30 or whatever it is for a switch when you can buy a normal one for 5!! Haha
gbh14 is offline
3 way switch , emg
V7 and V8 wiring with 3 way switch? ManicSubsidal Pickups & wiring 4 03-29-2009 03:17 AM
help with 3 way switch wiring mackself Pickups & wiring 4 04-23-2008 03:43 PM
EMG H-S-H WIRING / 5 way switch jasonmke Pickups & wiring 2 09-28-2007 09:09 PM
Hum-Hum, 3-way switch + Coil Tap Switch Wiring TAorama Pickups & wiring 1 06-19-2005 01:12 PM
Wiring to a 5 way switch on Jem 555 Greenie Pickups & wiring 1 08-30-2003 05:07 AM
