EMG wiring issue - Jemsite
post #1 of 4 (permalink) Old 12-28-2013, 11:43 AM Thread Starter
Exclamation EMG wiring issue
So I have an Ibanez ART100 i'm working on and I got the Zakk Wylde EMG set in them, but the only problem that I'm having is the wiring from the old switch. Not sure of which of the red/bare or white/bare set got into the bus or not. Plugged the guitar in and have sound coming out, but neither of the volume knobs are working. a step in the right direction would be grateful
Djmonize13 is offline
post #2 of 4 (permalink) Old 12-28-2013, 10:14 PM
Re: EMG wiring issue
is it a quick connect set or the older standard wiring ?
http://www.emgpickups.com/skin/front...t-b165-3wb.pdf
j.arledge is offline
post #3 of 4 (permalink) Old 12-29-2013, 01:15 AM Thread Starter
It's the quick connect set.
post #4 of 4 (permalink) Old 12-29-2013, 01:31 PM
i hate the quick connect system. I had one set that i installed and i ended up just cutting the quick connect terminals off and wiring them pickups in the "old" regular way. I recommend you do the same.
If i remember right the color codes on the active duncans and emgs are the same. You can also leave out the second 9 volt and wire it like regular, with the ground going to the input jack and your hot going to your pickup hot.
emg , solderless wiring , wiring 2 humbuckers , zakk wylde
H S H Wiring issue psp777 Pickups & wiring 4 01-20-2013 12:49 AM
Wiring issue! GuitarEvan07 Tech: Setup, Repairs and Mods 7 06-23-2009 03:39 PM
Wiring issue GuitarEvan07 Classified Ads: Guitars and Gear 1 06-20-2009 10:11 PM
JEM Wiring issue! Help! GuitarEvan07 Ibanez JEM, UV, JS & Other Signature Models 1 02-16-2008 10:41 PM
Wiring Issue Code001 Pickups & wiring 4 05-15-2006 02:05 PM
