Evolution Humbucker Individual Coil Readings - Jemsite
post #1 of 5 (permalink) Old 01-10-2013, 10:31 PM Thread Starter
I have acquired a set of Evo pickups and while I was checking the coils before I installed them. I notcied that the coils are mismatched quite a bit when I measure the resistance.
Bridge 8.1k and 5.7k total 13.8k
Neck 7.3k and 5.3k total 12.6k
Is this correct? or close...
this is the 1st set of these I have owned
thanks
MPX
manfromplanetX is offline
post #2 of 5 (permalink) Old 01-10-2013, 10:54 PM
Reviews: 120
Re: Evolution Humbucker Individual Coil Readings
DiMarzio make quite a few pickups with mis-matched coils. The Evos you listed are two of these such pickups. They will sound slightly different depending on which way they are installed.
LonePhantom is offline
post #3 of 5 (permalink) Old 01-10-2013, 11:10 PM Thread Starter
yes I know the Steve Special and a few others...but I didnt know the Evo was that way. I am putting them in a 540S I just got off of Falbo... its DY and the pickups blue and pink zebra...
I thought maybe the evos and the S would be a good match, normally I use either TZ and Reg Nortons or PAF Pro for neck... or F2 and and F1 or F4 for neck... straight in S bodys and replacing the F2 magnet for an alnico 5 in RG bodies...
anyone here use the Evos in an S body?
post #4 of 5 (permalink) Old 01-11-2013, 08:12 PM
I use an evolution in my bridge position of my ibanez S470DXQM. Sounds killer!
julzius is offline
post #5 of 5 (permalink) Old 01-14-2013, 12:33 PM
I think they are designed to be that way, I just bought a set, and noticed the same thing on mine. At the end of the day you just have to plug them in and decide if you like the sound.
ohaple is offline
FS/FT Single coil and humbucker Cameron1234 Classified Ads: Guitars and Gear 0 12-26-2012 05:04 AM
Coil tap the bridge humbucker? Possible? Blacksunshine Ibanez JEM, UV, JS & Other Signature Models 5 11-24-2008 10:17 AM
Evolution single coil? vaitrucci Pickups & wiring 19 05-02-2008 08:09 PM
HS-3, Evolution and humbucker from hell YngwieIsBetter Pickups & wiring 5 07-31-2004 09:31 PM
