F Spaced pickup or Standard for neck of RG550 - Jemsite
post #1 of 14 (permalink) Old 01-27-2017, 09:20 PM Thread Starter
Basic question but couldn't find previous threads on it.
I'm going to put gravity storms in the bridge and neck of my 1987 RG550.
From what I read I need F spaced size for the bridge, correct?
I've seen different opinions on the neck, with some saying standard instead of F.
Any quick feedback appreciated.
Thank you.
PS, I never use the middle single coil so was keeping stock PU there. If not any recommendations?
The TPS Report is online
post #2 of 14 (permalink) Old 01-28-2017, 02:40 AM
Re: F Spaced pickup or Standard for neck of RG550
F-spaced bridge pickup is wider then non F-spaced humbucker because Fender tremolo's string spacing is wider then Gibson style bridge string spacing. ( Fender spaced - F-spaced).
And neck position humbucker is usually not F-spaced, because neck string spacing is narrower then bridge string spacing anyway.
Actually, most people( in Seymour Duncan forum for example), think that there is no difference in sound between F-spaced and non F-spaced humbuckers. It is matter of string alignment with pickup poles. (And you can have blade pickup with no poles)
So in frankenstrat Van Halen put ordinary non F-spaced pickup in bridge position, ( there were not F-spaced pickups back then),
and Steve Vai, if I remember correctly, has bridge F-spaced pickup in neck position.
So there is no rule, just look for sound you like.
peromucho7 is offline
post #3 of 14 (permalink) Old 01-28-2017, 08:39 AM
I don't think you will hear much difference, but I'd choose the F-spaced version, simply because it exists.
I have both F-spaced Gravity Storms in my 1991 RG550 and the neck HB fits as good as the bridge HB. Especially the neck sounds awesome.
I have an Evo single in it and it works really nice with the humbuckers.
Cheers.
J.
Jemerator is offline
post #4 of 14 (permalink) Old 01-28-2017, 11:24 AM Thread Starter
Cheers.
J.
Fantastic! Thank you.
With the EVO single coil in the middle is it wired so that the 2 and 4 positions use a single coil of the humbucker and the EVO?
post #5 of 14 (permalink) Old 01-28-2017, 12:52 PM
Exactly. I use it in the standard Jem/RG wiring with the inner coils and single coil in 2 & 4.
post #6 of 14 (permalink) Old 01-28-2017, 01:18 PM Thread Starter
One last Q for you or anyone else. I see on the DiMarzio website they make Gravity Storms in many different colors. Unfortunately can only find "black" at most of the online sellers.
Any recommendation where to buy a set in some of the many colors available?
post #7 of 14 (permalink) Old 01-28-2017, 06:34 PM
most of the time you have to special order the bright colors. I have had great luck going through sam ash in the past.
j.arledge is offline
post #8 of 14 (permalink) Old 01-31-2017, 09:31 PM
You can check for sellers on the bay, or like noted above, special order from Dimarzio.
To answer your first question, if your guitar has a 43mm nut and F spacing at the bridge, Dimarzio recommends F-spaced in both bridge and neck positions. Most people, myself included, don't think it matters for the neck - but aesthetically, having both F-spaced looks better.. Almost all RGs will take F-spaced bridge because of their wide spacing. I believe Prestiges come with both pickups F-spaced from factory.
Steveche is offline
post #9 of 14 (permalink) Old 02-01-2017, 01:49 PM
Reviews: 10
banjomikez on [email protected] has a huge selection of pickups - he has gravity storm pups available in different colors...and he sends free swag with every order. I've ordered pickups from hims several times and the service was good. You should definitely check out his [email protected] site.
doriangrey is offline
post #10 of 14 (permalink) Old 02-07-2017, 04:54 PM
^ I remember getting free stickers when I ordered my Dimarzio set from them.
vm27 is offline
post #11 of 14 (permalink) Old 02-09-2017, 06:28 AM
All my JEMs / RGs have F Spaced pickups in the neck and bridge.
sebastian is offline
post #12 of 14 (permalink) Old 07-05-2017, 07:55 AM
Reviews: 4
All my RGs are loaded with DiMarzio. And all of them have F-spaced bridge AND neck pickups!
So, there... order F-spaced.
Crazy_Guitar is offline
post #13 of 14 (permalink) Old 07-05-2017, 07:56 AM
Reviews: 4
Yeah! I've had quite a few custom pickups ordered from Mike. He definitely kicks some serious butt!
post #14 of 14 (permalink) Old 07-05-2017, 05:23 PM
Reviews: 6
my RG has F-spaced pups on bridge and neck positions
satch_jr is offline
f spaced , gravity storm , rg550
RG550 Neck PUP F-spaced or Regular? [Debate] Trickae Pickups & wiring 16 04-02-2011 07:52 PM
RG550 neck pickup F spaced or not? pulkit Pickups & wiring 4 10-26-2010 05:41 AM
F spaced or standard for neck pickup? John R Pickups & wiring 11 08-27-2009 04:35 AM
pickup question standard or f-spaced? metalhead52 All Other Guitars (including Prestige) 1 03-22-2009 11:45 PM
RG550 Neck Pickup f-spaced? Marvel627 All Other Guitars (including Prestige) 21 08-17-2008 01:57 AM
