F2 not giving me enough presence - Jemsite
post #1 of 18 (permalink) Old 06-19-2013, 11:45 PM Thread Starter
After playing my UCRG1 (with an F2, C3 and F4) along with the rest of the band for the first time, I was disappointed to discover that the F2 doesn't cut through the mix as much as I would like it too. I love the way they sound but it's just too hard to hear over the rest of the band. I've played my RG550 with a set of Evos with the exact same amp/pedals and it does a wonderful job of cutting through the mix (but then again, they're Evos. Of course they do.) I've got some big gigs coming up next weekend and I would like to fix this issue before then.
Any suggestions for a bridge pickup that sounds similar to the F2 but with more presence? I've heard that the Gravity Storm is pretty similar, but since I already have Evo's in my other RG, I'd prefer to have a non-Vai sound in this guitar.
kfm946 is offline
post #2 of 18 (permalink) Old 06-20-2013, 12:06 AM
Reviews: 120
Re: F2 not giving me enough presence
DiMarzio Dominion. If that doesn't cut through I don't know what will!
LonePhantom is offline
post #3 of 18 (permalink) Old 06-20-2013, 12:21 AM
Just eq in the extra at the amp....2 notches should be all that's needed.
corey j grieve is offline
post #4 of 18 (permalink) Old 06-20-2013, 12:51 AM
If you like the sound--adjust your EQ and level. Let your amp do the work.
GodzillaPopcicle is offline
post #5 of 18 (permalink) Old 06-20-2013, 01:50 AM Thread Starter
I tried a bit, but I couldn't seem to get it The amp doesn't have a presence control. Presence lies mostly in treble and mids right? (At least for soloing)
kfm946 is offline
post #6 of 18 (permalink) Old 06-20-2013, 01:53 AM
Reviews: 120
Definitely give the Dominion a go then
post #7 of 18 (permalink) Old 06-20-2013, 02:05 AM Thread Starter
Does it sound similar to the F2? If not, what's it like?
kfm946 is offline
post #8 of 18 (permalink) Old 06-20-2013, 02:38 AM
F2 with steroid?
psychoshredder is offline
post #9 of 18 (permalink) Old 06-20-2013, 04:54 AM
Reviews: 120
Probably!
Yeah, it's kind of like a sharper F2. I consider the Dominion the Tone Zone perfected for basswood. The F2 is similar to the Tone Zone too, so yeah you'll dig it I reckon.
post #10 of 18 (permalink) Old 06-20-2013, 06:21 PM
RGTFanatic's Avatar
Can I assume that you have not adjusted the poles on the F2? These are VERY sensitive pickups. If you like the tone your getting from it, adjust the poles and pickup height to suit you presence needs. The F2 is a remarkably good pickup when adjusted properly. The only thing I've noticed about them is that some are lacking in low to low-mid response. This can always be fixed by adjusting the poles.
RGTFanatic is offline
post #11 of 18 (permalink) Old 06-20-2013, 06:29 PM
RGTFanatic's Avatar
BTW... For a new pickup, I agree that the Dominion set will be a good match, but not the same.
post #12 of 18 (permalink) Old 06-20-2013, 07:16 PM
Reviews: 120
Ah, I was just about to come back and mention this!
post #13 of 18 (permalink) Old 06-20-2013, 10:57 PM Thread Starter
Good point!! I usually do that to my pickups, I just got this one together and working, so I haven't yet. I'll do that and let you know how it works! thanks!
kfm946 is offline
post #14 of 18 (permalink) Old 06-21-2013, 12:43 AM
I second this, and it's what I was referring to.
If you like the sound--fibd a way to make it cut through.
You could also try a boost pedal.
I have to use one on guitars with vintage or medium output to keep from having to adjust my amp settings between guitars.
I already have a sound I love, but want to keep it set for all guitars.
I always let my amp do the work.
In fact--I'm starting to get away from high output pickups. You lose your amp's natural qualities if it's slammed with high output pickups.
post #15 of 18 (permalink) Old 06-21-2013, 01:49 AM Thread Starter
I'll definitely get one at some point, unfortunately right now when i'm gigging, I'm limited to only bringing my multi-effects board. And yes, I do back off on the volume pedal and crank it when I have a solo, but oddly that doesn't always seem to help. It's more a matter of presence than of volume.
kfm946 is offline
bridge pickup , presence
treble/presence issue with valveking 212 ozzuk Gear, Equipment, Recording & Off Topic 3 08-02-2012 01:59 PM
[YouTube] In the Presence of Enemies, intro + solo <- me Rachmaninoff Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 04-25-2009 02:04 PM
Me playing - In the Presence Of Enemies Pt.1 (Solo) Epicus Furor Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 6 08-19-2007 06:45 PM
Legacy head presence knob kubusiu Gear, Equipment, Recording & Off Topic 1 08-04-2002 09:23 AM
What does PRESENCE knob set? - Amp ignorance is my REAL draw Kramom Gear, Equipment, Recording & Off Topic 4 03-26-2001 05:01 PM
