Glued magnet - Jemsite
post #1 of 4 (permalink) Old 05-24-2013, 06:00 PM Thread Starter
Glued magnet
I really liked the sound of my TZ when I flipped the non-aged side of the magnet, gave more presence. Now I want to do the same thing with my AN but I noticed its glued and not much info on web.
Question is; If I remove the magnet, will the glued side sound good enough or should I buy a new magnet before doing this?
mertay is offline
post #2 of 4 (permalink) Old 05-25-2013, 12:58 AM
Re: Glued magnet
You'll be fine--just do it and let your ears decide.
GodzillaPopcicle is offline
post #3 of 4 (permalink) Old 05-25-2013, 04:06 AM Thread Starter
Re: Glued magnet
Thanks
mertay is offline
post #4 of 4 (permalink) Old 05-25-2013, 03:11 PM Thread Starter
Re: Glued magnet
incase anyone searches, it sound pretty good for solo work if I had to describe, the series sounded closer to the parallel position when the aged side of the magnet is used but much stronger. Oh keep in mind I had a capasitor 0.47 which lessenes the sub freq.s a bit.
Probably great for a 22 fret guitar but if anyone finds it too tight/edgy, one can place the screw poles higher to the strings this works very well.
mertay is offline
Installing Frets - glued v. unglued Silver Sable Tech: Setup, Repairs and Mods 24 04-04-2008 01:36 PM
Self Glued Neck spkenn5 Tech: Setup, Repairs and Mods 16 03-17-2008 10:11 AM
Glued Bolt-on neck Freaker Tech: Setup, Repairs and Mods 3 02-08-2005 06:18 PM
Ever use heat to remove a glued part???? oooo Tech: Setup, Repairs and Mods 1 01-27-2003 04:03 PM
Glued vs Bolt On - Pro's Con's? ripl3y Tech: Setup, Repairs and Mods 6 05-03-2001 11:28 PM
