ground loop prevention qwesion - Jemsite
post #1 of 1 (permalink) Old 11-18-2012, 09:20 AM Thread Starter
Hello .....Im in the process of hooking all my electronics back up on the bc rich (yikes) Old warlock since installing a Motherbucker & a domarzio in the neck. Although I have most of it all wired in, Iv e saved the actual ground system till last. I have 1 wire coming from Trem claw. 1 ground coming off theoutput jack ...... All I have for setup is 1 vol pot & 1 switch ......... Does anyone know what is the best method for avoiding a Ground Loop??
Ive HEARD ya have to make the strightest path from the claw to the output jack with No cut-backs anywhere,meaning cant run ground down to the pot then cutback & go to switch then go BACK again towards the Output jack, instead just keep it as straight as possible & simple as possible.
Im gonna use the Last thing b4 the OP jack as grounding point which will be Vol pot.
2DECADESSOFAR is offline
ground hum wiring
Let's talk injury prevention ironfistx Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 25 08-31-2012 09:01 AM
Ground Loop? LethalAe86TypeR Gear, Equipment, Recording & Off Topic 6 08-29-2007 08:42 PM
Bad ground???? Czech Pickups & wiring 5 11-19-2006 04:25 PM
2027 ground loop - a possible solution Scott of Actual Time All Other Guitars (including Prestige) 0 11-05-2001 09:49 PM
Legacy effect loop - possible ground loop hum? bill h Gear, Equipment, Recording & Off Topic 4 08-12-2001 03:05 PM
