I own a bunch of guitars. I have mostly Ibanez. a range from $300 RG series to Jem Premium . I cant afford the $3000 jem. but that neither here nore there. I notice on the Prestige RG655 and the RG 450m INDO that when plugged into the boss j
katana 100/212 and or ether amps that it I touch the trem arm or knobs (metal) that the Buzzing almost vanishes. is there a way to prevent the amount of Buzzing or do I want it to buzz? my other gutar that shall be nameless does not seem to have the buzzing it has EMG Active Pickups. and if this is a grounding issue might you suggest a method to fix this issue with out effecting the sustainiac pickup. thank you.
