H s H 5 way switch wiring without single coil - Jemsite
post #1 of 2 (permalink) Old 01-28-2018, 06:52 AM Thread Starter
Hello guys!
I own a '01 UV777PBK model and i just changed the bridge and neck Blazes with Titans. I would like to completely disable the single coil middle pickup (it messes my picking a little bit) and lower it's action to the level of the pickguard.
It would be awesome if i can still use the 5 way switch to coil split the humbuckers and also use them in parallel (middle position).
Any schematics available? I found some but i'm not shure if it wil work with the original 5 way switch on the UV.
Thanks!
PaulCorcio605 is offline
post #2 of 2 (permalink) Old 01-30-2018, 09:46 AM
Re: H s H 5 way switch wiring without single coil
if it has a vlx 91 switch you should be able to wire it like this
j.arledge is offline
IBZ USA C1 - Single coil wiring? comopasta Pickups & wiring 6 03-16-2016 10:40 PM
wiring issue with 2 humbucker 1 single coil dano1066 Pickups & wiring 7 07-21-2013 01:13 PM
s1 single coil ground wiring help e32lover Pickups & wiring 7 07-23-2012 04:36 AM
Wiring a Telecaster for Humbucker and single coil toma Pickups & wiring 11 07-17-2012 06:45 PM
fs/green blue velvet single coil dp170 dimarzio+5 way fender selector switch just42dave Classified Ads: Guitars and Gear 2 05-18-2008 07:49 PM
