help with 3 way switch wiring - Jemsite
post #1 of 5 (permalink) Old 04-19-2008, 10:31 PM Thread Starter
Hi i got an ibz rg470 with tone zone in the bridge , ibz inf in the middle and air norton in the neck with 5 way switch, i want to replace the switch for a fender type 3 way switch and eliminate the single coil and use only the humbuckers in a configuration:
pos. 1 bridge
pos. 2 inner coils
pos. 3 neck
how i got to do the wiring, i search in the web but i only found a different position 2 with the two humbuckers at the same time or with a different switch i think is a dpdt switch and mine is a fender type 3 way switch.
Thanx
mackself is offline
post #2 of 5 (permalink) Old 04-19-2008, 11:24 PM
Re: help with 3 way switch wiring
http://www.stewmac.com/shop/Electron...aswitches.html
it is a 5 way but it is very nice to have
j.arledge is offline
post #3 of 5 (permalink) Old 04-20-2008, 08:30 AM
Found this a couple of days ago and thought it was interesting. No idea if it works, but you should try it and report your findings. Ignore the top half of the diagram, obviously.
djohns74 is offline
post #4 of 5 (permalink) Old 04-20-2008, 03:33 PM Thread Starter
thanxxxxxxxxxxxxxxxx
thanx very much guys i'll try it and i'll tell u how it works
mackself is offline
post #5 of 5 (permalink) Old 04-23-2008, 03:43 PM Thread Starter
It Works
Hi Guys i do the wiring yesterday and it works perfectly thanx very much
mackself is offline
air norton , ibz inf , inner coils , tone zone
Ibanez RG 5 way switch wiring? (pics) kamix Pickups & wiring 10 03-29-2010 12:42 AM
wiring using push pull switch Jeff - CRO Pickups & wiring 4 09-06-2006 03:28 PM
Hum-Hum, 3-way switch + Coil Tap Switch Wiring TAorama Pickups & wiring 1 06-19-2005 01:12 PM
RG7620/7621: Alternate wiring using stock switch? bakerman Pickups & wiring 0 11-27-2002 09:46 PM
Wiring 2 HBs with a standard 5-Way switch - Is this possible kuma Tech: Setup, Repairs and Mods 2 03-25-2002 04:08 PM
