Help with AH4 humbucker wiring colors - Jemsite
post #1 of 9 (permalink) Old 03-31-2014, 04:01 PM Thread Starter
I'm replacing my wife's AH4 humbucker in her SA160 tonight with a Bill Lawrence (Bill&Becky) XL 500L. When I try to look up the wiring it's a bit confusing.
I have the SA160 diagram, and assuming it's correct (not sure of her model year, but it's purple sparkle), her guitar has an AH4:
The diagram I found for the lawrences doesn't appear to be right for their Ibanez example:
http://www.guitarelectronics.com/cat...g_color_codes/
So I'm not sure I should trust it.
Any thoughts on the right way to wire these up? The Iby diagram says nothing about hotness or south pole or any of that stuff. LOL
Thanks!
Bill
Billkwando is offline
post #2 of 9 (permalink) Old 03-31-2014, 04:11 PM
Re: Help with AH4 humbucker wiring colors
the AH4's white is hot. So the BL's red wire will go where the white wire from the AH4 goes.
The BL's green AND white will go where the red wire from the AH4 goes.
j.arledge is offline
post #3 of 9 (permalink) Old 03-31-2014, 05:47 PM Thread Starter
Awesome thanks!
and if I ever wanted to coil split it??
(still working out whether a push pull pot can fit in the SA cavity).
Much appreciated.
post #4 of 9 (permalink) Old 03-31-2014, 06:13 PM
the bridge is split in position 4 of the wiring diagram. So the switch is splitting the pickup already.
If you wanted to split it independently of the 5 way, it is really easy. Like you said you'd just need a push/pull pot or you could do a mini-toggle but that would mean you would have to drill a new hole in the cavity.
post #5 of 9 (permalink) Old 03-31-2014, 08:05 PM Thread Starter
Actually, that link I sent you to did indeed end up being wrong (or maybe it means Bill Lawrence USA rather than B&B). For the sake of science and Google, I figured I'd better report back before somebody sees it and does it wrong.
From http://wildepickups.com/Wiring___Tech_Info.html :
"All Pickups with White/Black/Red/Green/Blue Wires
White Wire -- Hot
Black/Blue Wires -- Ground
Red/Green Wires -- Twist together, insulate with shrink wrap or electrical tape for humbucking OR solder to either a push/pull or on/off switch for split coil."
That's exactly what I ended up with. I also find it interesting that they can't be bothered to tell you which wire goes to which coil.
Oh really? Wow. I wonder how I'd pull that off with this cthulu of wiring I have going on.
post #6 of 9 (permalink) Old 04-01-2014, 02:01 PM Thread Starter
I ended up screwing this up my first try, probably due to a bad solder joint. In the interest of not cross posting, if anybody wants to take a look, I already posted about it here:
http://www.jemsite.com/forums/f21/fi...ml#post1275334
Thanks!
post #7 of 9 (permalink) Old 04-01-2014, 05:08 PM Thread Starter
I realize, after reading around a bit, I only twisted the ends of the red and green wires together. Did they want me to twist them all the way up to the pickup? I read somewhere that untwisted pairs can cause hum. I also didn't insulate because only the ends that hit the solder point were exposed. Could it be a case of me not following directions?
post #8 of 9 (permalink) Old 04-01-2014, 05:50 PM
no your coil tap wires just need to be soldered together and then soldered to the switch.
You don't even have to twist them together.
so for the right color wires.
your AH4
WHITE : HOT
RED : COIL TAP
Bare : Ground
the BL
White : Hot
RED AND GREEN: COIL TAP
BLACK, BLUE AND Bare : ground
post #9 of 9 (permalink) Old 04-01-2014, 07:43 PM Thread Starter
your AH4
WHITE : HOT
RED : COIL TAP
Bare : Ground
the BL
White : Hot
Oh I gave up on that for the moment. Right now I'm just trying to get it so the guitar doesn't sound like crap in regular humbucker mode. That's what I was talking about when I mentioned the wire twisting.
I did it as a surprise for my wife, and needless to say she's gonna be SUPER surprised when she goes to play Rocksmith and she can't even hear herself hitting the strings.
ah4 , bill lawrence , pickup , sa series
Colored pickups, best matched colors for single and humbucker The Euphor Gear, Equipment, Recording & Off Topic 7 03-24-2012 11:46 PM
1 humbucker 1 volume wiring? Vinvm Pickups & wiring 6 07-13-2009 03:23 AM
wiring just one humbucker guitaritz Pickups & wiring 3 11-03-2005 11:34 PM
Wiring problems.... - the wires' colors are driving me crazy yuza Tech: Setup, Repairs and Mods 9 02-15-2001 08:53 AM
