help with Bill Lawrence L 500 pick up wiring - Jemsite
post #1 of 6 (permalink) Old 09-16-2013, 12:16 AM Thread Starter
hey dose anyone know if this can be done please its a tele set up but a HSS with a p/p vol and a p/p tone and as regular 5 way fender selector switch the humbucker is a Lawrence L500 4 wire plus bare wire and two adjust pole single coil with 2 wires i would like to split humbucker and maybe phase with one of the single coils if possible if anytthing just splitting HB would be fine thanks
beachrat2go is offline
post #2 of 6 (permalink) Old 09-16-2013, 12:24 AM
Re: help with Bill Lawrence L 500 pick up wiring
http://www.guitarelectronics.com/c=6...ring_diagrams/
see if any of those help.
What do your push pull knobs do right now?
j.arledge is offline
post #3 of 6 (permalink) Old 09-16-2013, 01:08 AM Thread Starter
well i had a different set up it was a p/p vol and 3 toggle switches no tone so i am assuming p/p was a splitter for HB
post #4 of 6 (permalink) Old 09-16-2013, 05:30 PM
you can do whatever then. You can do series/parallel on the BL or split it or do reverse phase on one pickup and do whatever with the bridge pickup.
Just nail down what exactly you want and i will get you a diagram or make a diagram for you.
post #5 of 6 (permalink) Old 09-16-2013, 06:50 PM Thread Starter
really just want to make standerard 5 way like on a Hss strat but with only 1 tone and if possible split humbucker with the p/p tone knob and i leave the p/p vol knob alone or dormant on the the pull half dose that make sence ?
post #6 of 6 (permalink) Old 09-17-2013, 10:12 PM
http://www.stewmac.com/freeinfo/i-lawrence.html
that gives you what your looking for as far as wiring the bridge up.
the plus sign will go to the same place on the 5 way switch that the red pickup wire would go to.
so use this diagram as a starting point. Your single coils have two wires, one for a ground and one for a hot. Just look for which wire runs to the switch (that is hot) and which wire will be grounded.
http://www.guitarelectronics.com/pro...SS5L11-01.html
just be clear you have 1 red, 1 white, 1 black and 1 green lead wire plus a bare wire ?
wire mod
Bill Lawrence L-500 CityofBlindingLights Pickups & wiring 20 09-19-2010 03:33 AM
Bill Lawrence L500 Vintage Wiring Codes? bdk Pickups & wiring 1 03-22-2009 10:18 AM
Bill Lawrence pickup wiring and how to tell what is what. Brando Clean Pickups & wiring 5 09-19-2007 09:47 PM
Problem wiring Bill Lawrence L500's in S470 Lamejohn Pickups & wiring 0 01-02-2007 02:30 AM
bill lawrence pick up (old L500) installed zendra Gear, Equipment, Recording & Off Topic 3 09-29-2002 03:25 AM
