HELP! Can anyone tell me about the VLX91 switch? - Jemsite
post #1 of 6 (permalink) Old 08-25-2003, 10:51 PM Thread Starter
I have an RG202X that comes with the 4 pole VLX91 switch. It has 4 poles, and 6 lugs for each pole.
What I'd like to know is (largely coz my multimeter died on me), if the switch is placed upright, say, on a table top, which lug is lug0, and how how are the remaining 5 lugs numbered?
Is it:
Or:
Would appreciate if someone could shed some light.
Thanks!
Alnico5 is offline
post #2 of 6 (permalink) Old 08-26-2003, 08:28 AM
would that it were that easy! the lugs go up one side and down the other.
check out the Ibanez wiring diagram for the 2020 [or the 2027, they should be the same]. it shows both sides of the switch in separate pictures and you can figure out which is which.
post #3 of 6 (permalink) Old 08-26-2003, 08:52 AM Thread Starter
Hi Scott, thanks!
I did try looking at the wiring diagrams on the Ibanez website, but before I could decipher anything, I got stuck at figuring out the wire color codes for the V7 and V8 pickups.
On a non-reversed polarity V7, can I say, the hot wire goes into the north coil, the green wire comes out of it, then connects to the south coil, and finally the white wire comes out of the south coil to ground? Is this correct?
I think the V7 has the magnet reversed, hence the hot wire is green instead of red, and the ground wire is black instead of white.
Can you help confirm/correct my understanding?
Thanks!!!
Alnico5 is offline
post #4 of 6 (permalink) Old 08-26-2003, 08:56 AM Thread Starter
To further add,... the reason I'm messin' with the wiring is, I'm changing the stock pickups (V7/V to Duncan Jazz and CC.
I have reversed the magnet in the Jazz (neck) so that it will be humcancelling when split and made parallel together with the bridge pup's north coil.
Instead of completely rewiring the RG2020X from scratch, I'm thinking of replacing the wires one for one. Meaning,...
V7 Red -> Duncan Black
V7 Green -> Duncan White
V7 Black -> Duncan Red
V7 White -> Duncan Green
Am I correct?
Alnico5 is offline
post #5 of 6 (permalink) Old 08-26-2003, 04:24 PM
flipping the magnet does not change the wire codes, it only changes the magnet polarity (North or South). (if you have a Duncan neck model, you might not need to do this, it might be flipped already -- check to be sure. DiMarzios don't come in "neck" and "bridge" models, so they have to be flipped).
changing the hot and ground wires like you describe above changes which coil is "first" and which is "second." this will change the phase when running in full humbucking mode, but it can also change which coil is on in coil cut settings, depending on what other wiring you've got going on.
not without studying the diagram! but this will help -- i dug up an old schematic of mine where i had numbered the VLX poles. see http://www.his.com/~sha3u/gear/vlx91.jpg .
using this, i'd recommend you go back to the diagram, pick an easy position like neck humbucker full on in position 1, and start figuring out the wires from there. in neck humbucker position with the Special 5 wiring, the hot will be connected to the hot switch output, the ground to ground, and the two wires that are the series link will have to be connected together by the switch.
as for V7 --> Duncan wire codes, check the Wiring 101 column at http://www.stewmac.com/ . translating DiMarzio to Duncan should work, assuming the Ibanez pickups use the same color codes as DiMarzio (anybody know for sure?).
post #6 of 6 (permalink) Old 08-27-2003, 08:44 AM Thread Starter
Scott, thank you so much!!! That diagram of the lug numbering is a god send!
Alnico5 is offline
bridge pup , ibanez pickups , ibanez wiring diagram , neck humbucker , wiring diagram
91' RG 565 Wiring diagram with a VLX91 5-way switch. dgabriel713 Pickups & wiring 5 08-06-2013 11:19 PM
FS UK: OTAX VLX91 switch (16 posted) axemanrio Classified Ads: Guitars and Gear 2 02-13-2011 03:22 AM
VLX91 switch in an RG565 causing endless headaches... JEMfreak Pickups & wiring 2 04-28-2010 05:58 PM
VLX91 vs standard 5 pos switch plugger Pickups & wiring 4 12-09-2008 05:35 PM
IBANEZ S470/EMG pickups/VLX91 switch and a stereo jackplug!! spacecadet2004 All Other Guitars (including Prestige) 0 04-19-2004 01:34 PM
