HELP! Liquifire/'D-activator combo in Rg7321 - Jemsite
post #1 of 9 (permalink) Old 08-21-2013, 10:11 PM Thread Starter
Exclamation HELP! Liquifire/'D-activator combo in Rg7321
So i just ordered/received a dimarzio d-activator 7, and a liquifire 7. I desoldered the old pickups and installed everything according to dimarzio's diagram that i found online and the neck pickup is WAY quieter than the bridge. what should i do? I've gotten quite frustrated with soldering by this point.
Djmonize13 is offline
post #2 of 9 (permalink) Old 08-21-2013, 10:26 PM
Re: HELP! Liquifire/'D-activator combo in Rg7321
try adjusting the pickup height?
MatiasTolkki is offline
post #3 of 9 (permalink) Old 08-21-2013, 10:27 PM Thread Starter
doesn't work, height is higher than the bridge and still nothing. a better way to describe it is that the output in general is half of what is should be.
post #4 of 9 (permalink) Old 08-21-2013, 11:50 PM
IbanezFreak777's Avatar
Reviews: 25
sounds like you wired it up wrong....
IbanezFreak777 is offline
post #5 of 9 (permalink) Old 08-22-2013, 12:01 AM Thread Starter
Followed the wiring diagram step by step
post #6 of 9 (permalink) Old 08-22-2013, 12:09 AM
Reviews: 120
Tap each row of pole-pieces with a screwdriver while plugged into your amp. Turn the amp up so you can hear it. Do both coils have the same volume for the tapping sound that comes through? If they don't it's wired wrong, if they are both the same but quieter than doing this to your bridge pickup you've probably got a bad solder joint somewhere.
LonePhantom is offline
post #7 of 9 (permalink) Old 08-22-2013, 09:20 AM Thread Starter
i think it may be a bad connection, because the neck pickup works fine in when it's connected as parallel, but when it's just the neck pickup in series that's when i have the problem.
post #8 of 9 (permalink) Old 08-25-2013, 08:49 PM Thread Starter
UPDATE - I resoldered everything according to the diagram form dimarzio's website and the problem still occurs but now with horiffic feedback. What should I do now, take it in to a music store
post #9 of 9 (permalink) Old 08-25-2013, 09:00 PM
Reviews: 25
YES !!
d-activator 7 , dimario , liquifire 7 , wiring
D-Activator / Liquifire combo impressions Curtis08ltd Pickups & wiring 0 01-04-2012 01:41 PM
RG7321 + D--Activator 7's Djmonize13 Pickups & wiring 3 11-18-2011 10:03 PM
FT crunch lab liquifire combo for your paf pro or fred combo surfthealien Classified Ads: Guitars and Gear 11 02-23-2011 11:44 PM
Liquifire / CrunchLab combo advices needed ! Agent540 Pickups & wiring 1 05-18-2010 09:59 AM
FS: Ibanez RG7321 w/ D-Activator 7 (2005) Mind's Mirrors Classified Ads: Guitars and Gear 2 07-05-2007 01:34 PM
