Help me pick out pickups for a vintage-sounding RG550 - Jemsite
post #1 of 16 (permalink) Old 07-14-2012, 03:19 PM Thread Starter
Reviews: 5
So, I have an extra RG around the house and I'm thinking of rewiring it for a different sound. I have a JEM7VWH and an RG570FM with Evolutions. I also have a strat that has a great sound but, of course, will never play like a wizard neck. So here's my idea: drop lower output "vintage"-sounding pickups in an extra pickguard and try to get a strat sounding RG.
Per the sticky at the top:
RG550
24 fret, maple board
Basswood body, pickguard mounted pickups
Original Edge trem
Sounds a bit "dark" with the DiMarzio's currently installed.
Suggestions?
jem7vwh is offline
post #2 of 16 (permalink) Old 07-14-2012, 04:21 PM
Super Moderator
Re: Help me pick out pickups for a vintage-sounding RG550
Either the Eric Johnson set or a pair of DiMarzio 36th anniversaries
OK...
Having read the post again, if you want vintage strat sounds, I'd go for three DiMarzio "Areas".
jono is offline
post #3 of 16 (permalink) Old 07-14-2012, 04:27 PM
Fender Texas specials or whatever they're called? Fender SCNs?
BlanK is offline
post #4 of 16 (permalink) Old 07-14-2012, 07:42 PM
Do what I did-
Fender Texas Specials
sebastian is offline
post #5 of 16 (permalink) Old 07-15-2012, 11:32 AM Thread Starter
Reviews: 5
Thanks for the suggestions guys. And Sebastian, that looks almost identical to what I was planning, except with a maple board!
jem7vwh is offline
post #6 of 16 (permalink) Old 07-15-2012, 04:25 PM
Reviews: 130
Texas Specials will sound great... Also look at the Dimarzio pre-wired Area pickguards.
racerevlon is offline
post #7 of 16 (permalink) Old 07-15-2012, 06:13 PM
RGTFanatic's Avatar
OK...
Hands down....best suggestion all day.
The 36th can sound VERY strat like (when split) if you order them with the 4-wire config. The bonus is that they're more versatile if you need "more" out of the same guitar.
RGTFanatic is offline
post #8 of 16 (permalink) Old 07-18-2012, 09:21 AM
Funny.. I have a RG570 that I was thinking about cleaning-up it's sound a bit. As I have several other guitars all which have hotter pu's. I'm too stuck on getting a pair of 36th anniversaries. I am a concerned though they will be a bit "thin sounding" with the trem? I've heard this complaint with the PAF Pro which I would assume is a bit hotter than the 36's? Anybody running a set of 36's in an RG now?
jetflyer01 is offline
post #9 of 16 (permalink) Old 07-18-2012, 05:17 PM
Do you want singlecoils or humbuckers? Texas Specials aren't bad - the middle position is my favorite "traditional" singlecoil I've tried. The vintage stagger irritates me, but if you want Strat-y sounds out of a dark RG550, they might do the trick.
Drew is offline
post #10 of 16 (permalink) Old 08-02-2012, 10:40 AM
For a vintage Strat type sound: Seymour Duncan SSL2. Good shimmer, chime, and beef with some gain. The A5 magnets should brighten things up.
For a slightly more powerful bridge pu, a Twang Banger is good, which has a copper plated steel baseplate, giving a more Tele style vibe.
Ashurbanipal is offline
post #11 of 16 (permalink) Old 08-03-2012, 11:32 AM
suhr have got some nice vintage style pickups, and if u want hot vintage, they've got their aldrich signature set! although they were designed for a LP/mahog body, so dnt know what they'd be like in basswood?!
rickybaby1985 is offline
post #12 of 16 (permalink) Old 08-03-2012, 06:48 PM
Yeah, I've been thinking of putting a Twang Banger in the bridge position of my Strat, but then I look over and seem my RG550 and think "What if..?"
Petie is offline
post #13 of 16 (permalink) Old 08-03-2012, 08:38 PM
GUITARMAGEDDON is offline
post #14 of 16 (permalink) Old 08-03-2012, 11:30 PM
Hehe. I suppose my only beef with the Twang Banger is that it doesn't appear to come with flat poles, and with a flat radius axe like a 550, the D and G strings might end up being louder than the rest. You'd probably have to go Custom Shop for flat poles, which means extra $$. Great sounding pu though - adds muscle without taking away the Strat vibe.
post #15 of 16 (permalink) Old 08-06-2012, 08:18 PM
Then would you say with the proper capacitance (aka 2 tones and a vol or at least a capacitor pretending to be 3 250k pots) a middle Texas special will be able to pull vintage tones on a basswood rg or jem?
Right now Im sort of wanting what the op wants, atm I have just an evo and liquifire with no middle but I'm thinking about just making the middle a one trick pony for bluesy tones. But I'm thinking about changing the neck pup to something more versatile if the middle can't do it.
newbieguitarmaker is offline
550 , pickups , rg550 , vintage
FS: '87 RG550 RFR, Vintage humbuckers Jeminizer Classified Ads: Guitars and Gear 2 05-10-2010 11:41 AM
Looking for dark sounding pickups in the bridge Orochimaru Pickups & wiring 14 10-08-2009 08:16 PM
Guitar pickups sounding right? Ant1981 Pickups & wiring 0 05-15-2006 12:11 PM
Pickups Dark or Bright Sounding ??? extremist777 Pickups & wiring 1 09-17-2005 08:20 PM
Changing pick-ups on a RG550. RichardGS All Other Guitars (including Prestige) 5 08-21-2003 07:51 AM
