Help Me with Pickups - Jemsite
post #1 of 16 (permalink) Old 01-04-2012, 01:31 PM Thread Starter
Reviews: 13
I want to create a sound which incorporates the tonal qualities of John Petrucci's playing, as well as Joe Satriani's.
What I mean by this is that i want that clear tone the Petrucci gets, as well as having the cool harmonic screams that Joe is so popular for.
My rig is as follows
Ibanez RG320fm- basswood, 2 ring mout humbuckers, 24 fret rosewood fingerboard
to
Standard Crybaby->Satchurator->Fender Frontman 212r
FX Loop: Delay (To be Determined)
My original thoughts were to have a Crunchlab in the bridge and a PAF Pro or Joe in the neck, but im not sure, and would appreciate input from the Jemsite community here.
I am not too particular on the brand of pickups also.
DownHomeRock is offline
post #2 of 16 (permalink) Old 01-04-2012, 02:33 PM
Re: Help Me with Pickups
really comes down to what kind of qualities from these two players you want to combine. If you like quacky pentatonic solos that satriani plays alot than Paf Pro/Joe in the neck will be good. If you like long note leads and fast picking on neck pickup a'la Petrucci, Liquifire is a better choice. When you play fast alternate picking with paf pro, those quacks are more pronounced and sounds less smooth. As for the bridge, it's a similar story. If you want to do more of a chugga-chugga rhythm, get the Crunch Lab. Joe's pickups are more midd-rangy which is nice for lead but can sound boxy unless you scoop the cr*p out of it with EQ
bancika is offline
post #3 of 16 (permalink) Old 01-04-2012, 08:48 PM Thread Starter
Reviews: 13
So really, I cannot combine the two? Just one or the other. Hmm...
post #4 of 16 (permalink) Old 01-04-2012, 09:31 PM
well, they are quite different. You can try to get something in between, but it would be a compromise on both sides. That's why I suggested picking one of their pickups for bridge and the other for neck, based on your preference. I think you can safely mix and match any combination CL/MoJoe/Fred with any of AirNorton/Liquifire/PafPro/PafJoe
Cheers
bancika is offline
post #5 of 16 (permalink) Old 01-05-2012, 01:53 PM
Buy a Fred/Mojoe and a Crunch Lab along with an Liquifire and a PAF Joe. Then take the pickups appart and take combine the coils to get a hybrid of the two sounds.
If that sounds like too much work, consider a Mo Joe / Tone zone in the bridge, and a PAF Joe / Liquifire in the Neck
SpikeSocietySucks is offline
post #6 of 16 (permalink) Old 01-05-2012, 04:55 PM
Tone Zone probably won't have the clarity he's after, I have it and it's very fat
bancika is offline
post #7 of 16 (permalink) Old 01-05-2012, 07:42 PM
I agree with you there, it's very very fat, but can be made to sound awesome with the right amp eq. I mentioned tone zone because it's a pickup John used to use, and it has some nice Fred things going on.
As for the mo joe, that pickup has an interesting eq. I initially thought it would just be a hotter fred, but in reality it's a whole different beast.
Taking some time to think about it, a double norton setup could nail this guys goal, the norton is right between the Fred and Tonezone, so it's gonna get elements of that satch lead, along with some nasty crunch petrucci's know for.
Up in the neck it would retain aspects of both players. Smooth like John with the right eq setting, or guttural and quacky like satch when needed
post #8 of 16 (permalink) Old 01-06-2012, 02:28 AM
Reviews: 6
I've got a Paf Joe in a basswood RG. I hesitated with the liquifire. I think the liquifire sound is really the solo sound of Petrucci, especially in the song on the Back of Angels.
The Paf Joe has a more balanced EQ, and has slightly less output.
I truly love this pup, but it's not really intended to shred soloing. Nevertheless, I'm able to have some cool sounds from it, even when I'm shredding.
So if you want more midrange (probably more cut through the mix, which is helpful if you play in a band with 2 guitars) go for the Liquifire (Actually the Joe can also cut through the mix, but it has less midrange). If you want to be able to get some vintage sounds on one side and cool satured tones on the other one, go for the Paf Joe. As SpikeSocietySucks said, the Paf Joe is a bit quacky, but not that much, just great (IMO at least). The Joe EQ on the DM website shows it has a lot of treble, but it's really balanced, there are not that much treble, the low frequencies can be intense depending on your sound when you play above the 12th fret of the 2 low strings
Hope this helps!
satch_jr is offline
post #9 of 16 (permalink) Old 01-06-2012, 02:35 AM
Reviews: 6
Cool Re: Help Me with Pickups
One more, to get an idea of the Paf Joe in my basswood RG550: listen to that piece of music, the 2 lead parts (right and left) are both with the Paf Joe:
http://soundcloud.com/mathiasremy/no...ose-2011-11-08
satch_jr is offline
post #10 of 16 (permalink) Old 01-09-2012, 11:16 AM Thread Starter
Reviews: 13
what do you guys think about a fred in the bridge and an air norton in the neck?
post #11 of 16 (permalink) Old 01-09-2012, 02:16 PM
Reviews: 6
For sure you will not get the JP sound with a fred. It as pretty much treble, and will lack on the outpoint point of view, IMO.
I've a fred in a swamp ash Kawai Aquarius, this is what I get.
satch_jr is offline
post #12 of 16 (permalink) Old 01-09-2012, 02:33 PM Thread Starter
Reviews: 13
i was thinkin i would get satch's bridge tone, and be ableto get petrucci neck tone with the ability to create somethig else if i want to. I am thinking that the fred/Air norton combo is what im looking for.
post #13 of 16 (permalink) Old 01-09-2012, 06:05 PM
that should be pretty versatile combo, why not
the biggest issue will be palm muted rhythm because fred is middy and you'll need to scoop it quite a bit. Since it's less powerful even than Steve's Special, you'll be left with not much after scooping mids
If you don't care about that it'd be fine.
bancika is offline
post #14 of 16 (permalink) Old 01-09-2012, 08:06 PM
Well my solution would be get a 2nd guitar, Like an RG 550,570,750,770,520,3120, and Put the CrunchLab and Liquifire in the one guitar and a Mo Jo/Fred PAF Joe in the other guitar then use the guitar that is called for depending on the sound that you want combining the two together doesnt really work well you end up with a lesser combo no matter how you combine them. Good Luck
corpraider69 is offline
post #15 of 16 (permalink) Old 01-09-2012, 08:25 PM Thread Starter
Reviews: 13
I had the notion of doing so. I plan to have a Warmoth guitar built somewhere down the road, so eventually i will do this, but for now i would rather spend $140 or so and just get some really versatile pickups.
feedback on pickups JEM777vbk - My pickups keep feebacking, Alinde Tech: Setup, Repairs and Mods 15 01-16-2010 03:05 AM
WTB: Dimarzio pickups MoJoe, any Air Buckers any 7 string neck pickups Devo Classified Ads: Guitars and Gear 2 10-29-2008 06:29 PM
Gibson Pickups vs. Seymour Duncan pickups Force2BRW Pickups & wiring 3 07-10-2008 03:51 PM
direct body pickups vs pickguard pickups? jsdetrait Gear, Equipment, Recording & Off Topic 3 06-25-2002 12:18 PM
pickguard pickups vs direct body mont pickups! jsdetrait Ibanez JEM, UV, JS & Other Signature Models 3 06-25-2002 09:14 AM
