Help with pickup swap - Jemsite
post #1 of 5 (permalink) Old 09-28-2009, 04:38 PM Thread Starter
I'm having alot of trouble wiring a dimarzio evolution into the bridge position of my RG3EX1 guitar. I've looked at every wiring diagram I can find and I still don't know where to solder the different wires. My stock pickup has only a white, red, and an uncovered wire. The evo has a red, green, black, white, and uncovered wire. Its a standard HH setup with 1 volume and one tone. Here is a picture.
Edit: never mind I apparently can't.
Can someone help me out. The dimarzio wiring diagram has some switch in it I've never seen before.
Captaincohny is offline
post #2 of 5 (permalink) Old 09-28-2009, 05:06 PM Thread Starter
Re: Help with pickup swap
Nobody?
I think I'll just wing it.
post #3 of 5 (permalink) Old 09-28-2009, 05:34 PM
Can't find a diagram for the rg3, Usually for the Evo, the red is the signal output the black and white are soldered together as the coil tap and the green is the ground, I guess the uncovered wire is the ground on the one you have and either the red or white is the signal with the other being the tap wire, have a go red for red and black/white for white and see if it's ok, if not swap the red and black/white...
Jim
Vim Fuego is offline
post #4 of 5 (permalink) Old 09-28-2009, 07:13 PM
Reviews: 15
Jim
Yup, that's right.
Bare and green together, to where the bare wire was
Black and white together, to where the white wire was
Red to where the red wire was
MarkE is offline
post #5 of 5 (permalink) Old 09-29-2009, 05:01 AM
Look here.....
some options for wiring... choose what you want.
seymourduncan.com/support/wiring-diagrams
Marcel-JS-build is offline
Pickup Swap Alopikal Pickups & wiring 2 04-26-2009 03:32 PM
Pickup swap for RG2020xtb pierce34celtic All Other Guitars (including Prestige) 20 06-27-2007 10:05 AM
Pickup swap video how to? 70Seven Pickups & wiring 3 05-15-2007 10:32 AM
Pickup swap. All eyes here! pinto79 All Other Guitars (including Prestige) 0 12-27-2005 05:30 AM
Just did a Pickup swap, what to look for? Triangle Pickups & wiring 4 06-09-2002 01:08 PM
