Help with ungrade Ibanez S770PB - Jemsite
post #1 of 21 (permalink) Old 06-27-2012, 02:44 AM Thread Starter
Hello Guys my name's Mike, im from Surfers Paradise Australia been playing music for over 20 years now and play several types and styles of music
Love guitar and most string instruments like Sitars
I recently purchased an Ibanez S770PB , and must say that its a great guitar but unfortunately not heavy enough for my needs which is a harsh Industrial Metal sound.
The Guitar has a Mahogany Body with Poplar Burl Top
The Guitar also came with stock pickups which are
Bridge - INF2
Middle - INFS1
Neck - INF2
these arnt bad but i was thinking to changing them to
Bridge - Seymour Duncan SH-13 ( i had previously BL L500XL in a Jackson)
Middle - DiMarzio Air Norton S DP180
Neck - Seymour Duncan SH-8n Invader (or keeping the INF2) or
DiMarzio PAF pro
Is this a weird Mix ?? I never seen ppl mix DiMazio and SD's together ?
Can anyone suggest any Middle and Neck pick-ups that would go with the SH-13's or any other cool combos
BTW I already have purchased the SH-13's
Thanks in advance
sweet daddy jones is offline
post #2 of 21 (permalink) Old 06-27-2012, 03:11 AM
Reviews: 120
Re: Help with ungrade Ibanez S770PB
For harsh industrial sounds I'd consider EMGs. That or Invaders bridge and neck.
LonePhantom is offline
post #3 of 21 (permalink) Old 06-27-2012, 03:17 AM Thread Starter
thanks , not much of an EMG fan though
what about the mid pickup ?? though
post #4 of 21 (permalink) Old 06-27-2012, 04:21 AM
Reviews: 120
Do you really get much use out of your middle single when playing your style of music? I've never really had a use of it when playing industrial style. I wouldn't bother replacing it if you wouldn't really use it.
post #5 of 21 (permalink) Old 06-27-2012, 05:01 AM Thread Starter
Fair point
Another question then
My other guitar the Ibanez RGA42FM Has the IBZ LZ Active pickups
Would it be hard/costly to install the EMG 81/85 combo in them
I know that the EMG's require 9V for starters and the RGA has only a 2xAA batteries
I have some money saved up but don't want to spend a fortune on a custom job
Thanks for ya help though
post #6 of 21 (permalink) Old 06-27-2012, 05:06 AM
Reviews: 98
Originally Posted by sweet daddy jones View Post
Fair point
If you swap out the pickups for EMGs--you'll also be installing the included EMG electronics. All of your original pickups and active components will be gone, so that's not an issue.
AlaskaBat is offline
post #7 of 21 (permalink) Old 06-27-2012, 05:18 AM Thread Starter
Actually I think I made a fool of myself I believe they just have passive pu but the batteries are for the eq ..hmm
post #8 of 21 (permalink) Old 06-27-2012, 05:37 AM
Reviews: 98
Yep--it's only for the mid cut circuit.
Just slap some Dizmarzio Dominions in and rock on, bud!
post #9 of 21 (permalink) Old 06-29-2012, 10:03 AM Thread Starter
Okie got the EMG 81/85 Zakk Wyld pu set for the RGA42FM
Will install that in few weeks , I'll change the bridge pu on the S770 to the Dimebucker
My question now is this
1) Is there any point retaining the RGA eq on the RGA42 if installing the EMG's Will it even work ??
2) I saw these 18v upgrade kits for the 81/85's any point getting these ? Will it really increase the sound that much ?
Cheers
post #10 of 21 (permalink) Old 06-29-2012, 10:24 AM
Reviews: 98
Cheers
That EQ circuit has no bearing in what pickups you put in, however--you'll need room for both battery packs.
Concerning the 18v mod--EMG enthusiasts seem to love it.
post #11 of 21 (permalink) Old 06-29-2012, 06:32 PM
Reviews: 120
Don't buy an 18V upgrade, waste of money. Make it yourself. Get 3 9V battery snaps and wire each red to another's black, and so forth. Easy to do! That all they are.
post #12 of 21 (permalink) Old 07-01-2012, 06:02 AM
You should have gotten the EMG X's because they have the headroom of a regular EMG @ 18v.
reign_of_blood is offline
post #13 of 21 (permalink) Old 07-01-2012, 08:11 AM Thread Starter
all good i got the 81/85's for $150 AU brand new so saved over $100 here in oz which is a joke really
and the 18V kit with a select switch was $5 so didn't really care much bout that
Anyways this is for the RGA42FM
My issues now are these:
1) Do I want 4 knobs (which i have no room for in a RGA 2xvol 2xtone)
2) 3 Knobs 2xvol 1xmaster tone or
3) 2 Knows 1Vol x 1Tone .. yes I do use tone BTW
4) do I keep the Ibanez EQ ?? will it work with 9/18v set up since the IBZ PU's are 3V ??
since when i look at the RGA42 wire diagram the EQ shows a +/- 3V switch
no biggie I guess , i dont mind the EQ though it makes the sound go bit Muddy
Again Cheers for all your help , i'll get onto the RGA in a few 2 weeks just waiting on a solderless 3 way selector to come in .
Getting the S770 Done tomorrow , will be getting the SH-13 Dimebucker installed in the bridge
post #14 of 21 (permalink) Old 07-01-2012, 09:22 AM
Reviews: 98
I already told you about the EQ--you can't run it from the EMG power supply, and would have to keep the power source separate or you'll fry the board.
post #15 of 21 (permalink) Old 07-01-2012, 04:52 PM
Reviews: 120
Just put in a volume and tone, like what is already set up in your guitar. Keep it simple.
dimebag , s770pb , sh-13 , shs
S Content. Played a S770PB!!! Impressed satchmo72 All Other Guitars (including Prestige) 2 02-24-2011 03:20 AM
s770pb fans cranick All Other Guitars (including Prestige) 18 02-20-2011 03:27 AM
My New S770PB JZwengel All Other Guitars (including Prestige) 4 11-23-2010 08:31 PM
