HELP!! Weird SSS wiring problem - Jemsite
post #1 of 5 (permalink) Old 06-06-2012, 09:27 PM Thread Starter
I've been putting together an SSS strat since almost all my other guitars have humbuckers. I Wired in the pickups to the guitar with 1 volume 2 tone knobs and a 5 way switch. Using a screwdriver to tap on the pickups to test if they are working, I tested the pickups. positions 1-4 works as they should (neck, neck-middle, middle, middle-bridge) but position 5 doesnt work, i get no sound despite the fact that the pickup is working when on the middle and bridge together. can anyone think of a reason why?
ZachSZY is offline
post #2 of 5 (permalink) Old 06-07-2012, 04:32 AM
Re: HELP!! Weird SSS wiring problem
Can you post a picture of how you have it wired? And/or a diagram used?
I know SSS wiring is simple, but you'd be surprised how easy it is to screw up something simply.
It is odd that it works in position 4 and not 5...
MicJustMic is offline
post #3 of 5 (permalink) Old 06-07-2012, 04:35 AM
Reviews: 98
Sounds like you've got a bad switch connection.
AlaskaBat is offline
post #4 of 5 (permalink) Old 06-07-2012, 06:19 AM
Does your wiring look like this:
xXLinkageXx is offline
post #5 of 5 (permalink) Old 06-08-2012, 08:53 AM Thread Starter
yup it all looked correct, so i just decided to remove the wires from the bridge pickup and then redo them, and wouldn't you know it, problem solved.
ZachSZY is offline
not working , positions , single coil , strat
Weird Guitar Problem aliendough Tech: Setup, Repairs and Mods 10 11-11-2011 02:34 PM
Having a weird problem with an Evo Mark_McQ Pickups & wiring 2 10-28-2011 11:08 AM
Weird problem Jack Secret Tech: Setup, Repairs and Mods 2 07-20-2006 09:51 PM
Weird noise problem zEr0 Tech: Setup, Repairs and Mods 15 06-03-2004 02:26 PM
Problem with my Morley PVO - Very weird! carlos seo Tech: Setup, Repairs and Mods 6 12-25-2001 09:30 PM
