help on wiring active pickups to emg battery/output jack - Jemsite
post #1 of 2 (permalink) Old 02-01-2003, 06:13 AM Thread Starter
hi,
im installing active emgs into a jem body, however the battery/output jack on the emgs isnt long enough to pass through the jem body. The jem output jack is about 2 inches compared to about 1/2 inch on the emg battery/output jack. Does anyone know if i can just wire the battery fitment onto the existing jem output jack?
live4love is offline
post #2 of 2 (permalink) Old 02-03-2003, 04:10 AM
The jack is different...the stock JEM jack is a mono jack, whereas the EMG has and NEEDS the stereo jack. The stereo jack acts as a battery switch. When you plug in a guitar cable, the battery is engaged to power the pickups' preamps. If you wire the EMGs to the mono jack, the battery connection will always be on, and your batteries will last very shortly. Likewise, if you put in a stereo jack, and forget to unplug your cable, the battery is draining. Always unplug your guitar!
You can get stereo versions of the jack in a Jem at any repair shop or electronics parts store...take the original jack with you, and tell them you need a stereo version that's identical...
Akhenaten is offline
Wiring a stereo output jack mono nsabino Pickups & wiring 13 09-06-2010 05:50 PM
Replacing Active Ibanez Bass Battery Connector Destroyer/Artist Gear, Equipment, Recording & Off Topic 2 12-04-2009 12:22 PM
Output Jack riconaka Tech: Setup, Repairs and Mods 0 03-16-2006 02:03 PM
help wiring an output jack on my 77dbk prefontainenike Pickups & wiring 1 12-22-2005 05:33 PM
Battery activation on 2027 - when is it active? tomizm All Other Guitars (including Prestige) 6 06-06-2001 01:14 AM
