HH with Five Way Switch - Jemsite
post #1 of 16 (permalink) Old 01-26-2014, 06:54 PM Thread Starter
Hi guys,
I did search over the internet for this HH combination but without success.
Found approaching wiring diagrams but the third position was not good.
1 Bridge
2 //Bridge
3 //Bridge // //Neck
4 //Neck
5 Neck
Is the wiring possible with a DiMarzio EP1112 or an Ibanez VLX91 ?
Thank you.
(And sorry for my bad english)
EDIT
HERE IS THE WIRING
Heep is offline
post #2 of 16 (permalink) Old 01-26-2014, 08:23 PM
j.arledge is offline
post #3 of 16 (permalink) Old 01-26-2014, 09:18 PM Thread Starter
Re: HH with Five Way Switch
Thanks for searching but the third position is not what I want.
Looking closely at this wiring makes me wonder if that is doable with "only" four poles.
Heep is offline
post #4 of 16 (permalink) Old 01-26-2014, 10:12 PM
i dont understand what you want for the middle position then .
post #5 of 16 (permalink) Old 01-26-2014, 10:23 PM Thread Starter
All the coils in parallel.
Heep is offline
post #6 of 16 (permalink) Old 01-26-2014, 10:41 PM
do a 3 way switch and have two push/pull pots. The two push/pull pots would give you the combo you want.
post #7 of 16 (permalink) Old 01-26-2014, 10:57 PM Thread Starter
Yeah I know that but for this guitar I am searching for simplicity and speed...
Heep is offline
post #8 of 16 (permalink) Old 02-06-2014, 05:30 PM
Let me check with some of my pickup wiring genius buddies and see what we can come up with.
Petie is offline
post #9 of 16 (permalink) Old 02-08-2014, 06:23 AM Thread Starter
Thank you for your interest.
At the DiMarzio's site I found an approching diagram where the third position was the outer coils of each pickup in parallel.
I emailed them and they said it "should" be possible.
Heep is offline
post #10 of 16 (permalink) Old 02-09-2014, 04:54 AM
I don't think that's possible, you will need four hot slugs which are not connected to anything else in position 3. and you will also need two slugs for grounding, that will be six slugs for position 3. Sorry dude.
tony777 is offline
post #11 of 16 (permalink) Old 02-10-2014, 07:26 PM
You're right Tony - I tried that wiring scheme with a 4-pole 5-way; ran into the roadblock of needing one more pole to accomplish it.
So you're right; there'd have to be another switch involved to get that combo.
steve is offline
post #12 of 16 (permalink) Old 02-11-2014, 12:27 AM
Reviews: 6
Hello
what you seem to obtain is a wiring like the one below, which can be done with a standard 5-way switch.
Here are the combinations you will get:
1 bridge humbucker
2 bridge split (you can choose the coil by choosing the coils during the wiring)
3 the chosen coils of the bridge and neck (I guess I have the outer coils, i don't remember the way of installation)
4 neck split (you can choose the coil by choosing the coils during the wiring)
5 neck humbucker
I must say I found it, this is not a wiring I created, it already exists.
This wiring is great, I found it once on a website and copied it on a paper quickly. Since that time I couldn't find it anymore on the web.
Here it is again, but I'm sharing it.
This might be the wiring which DM was taling about.
Hope this helps.
satch_jr is offline
post #13 of 16 (permalink) Old 02-12-2014, 03:04 PM Thread Starter
Thx for your replies guys.
I think I did it ( I hope ...)
This is with dimarzio color code.
Can the experts confirm it is good ?
Heep is offline
post #14 of 16 (permalink) Old 02-12-2014, 03:45 PM
I'm impressed ;-)
Yes I think it will work. (not claiming to be an expert though)
tony777 is offline
post #15 of 16 (permalink) Old 02-12-2014, 03:59 PM Thread Starter
I had just to think "you dont have two humbuckers, you have four coils"
Heep is offline
Quesiton about corresponding ibanez 5 way switch diagrams for a fender 5 way switch GuitarEvan07 Tech: Setup, Repairs and Mods 0 06-19-2009 08:20 PM
Make a 5 way switch a kill switch? GuitarEvan07 Pickups & wiring 11 04-15-2009 02:19 AM
Could i change the 2 position switch of my RG620x to a 3 position switch? supergirl20_06 Tech: Setup, Repairs and Mods 4 05-10-2007 04:27 AM
RG620x could i change the 2 position switch to a 3 position switch without any mod? supergirl20_06 Pickups & wiring 6 04-25-2007 06:12 AM
Hum-Hum, 3-way switch + Coil Tap Switch Wiring TAorama Pickups & wiring 1 06-19-2005 01:12 PM
