HHH 4 conductor wiring with 5 way switch. - Jemsite
post #1 of 8 (permalink) Old 12-07-2007, 11:30 PM Thread Starter
Reviews: 13
Anybody got a 3 dimarzio humbucker wiring with 4 conductors wire to a 5 way ibanez switch with 1 volume and 1 tone?
Here's the config
1) Neck full humbucker
2) Neck and middle split humbucker
3) Middle Full humbucker
4) Bridge and middle split humbucker
5) Bridge full humbucker
Zepp3lin is offline
post #2 of 8 (permalink) Old 12-08-2007, 11:14 AM
Re: HHH 4 conductor wiring with 5 way switch.
Hi, here's the circuit based on a VLX91 switch (from Ibanez) you could use a Megaswitch if that's easier to get hold of.
The Output goes to the volume pot.
The earth (3 blue horizontal lines) goes to the pot casing.
The Volume and Tone circuit is available ot either DiMarzio or Seymor Duncan.
Jim
Vim Fuego is offline
post #3 of 8 (permalink) Old 12-09-2007, 01:18 AM Thread Starter
Reviews: 13
Thks man, any other complate circuit drawing available for 3PS1CGAE5 switch 5 Way?, mine is not the VLX91 switch.
Zepp3lin is offline
post #4 of 8 (permalink) Old 12-09-2007, 05:08 PM
OK, That's a litle more difficult! I can give you what you want for the first three options, not the last two:
4) Bridge and middle Full humbucker
I've added a push pull switch which coil taps the middle and bridge humbucker
to get the other options.
Jim
post #5 of 8 (permalink) Old 12-10-2007, 11:03 AM Thread Starter
Reviews: 13
How about just the 5 way(3PS1CGAE5) switch alone, how is it connected?
You mean if the 5 way switch alone is use all will be humbucker mode? like in
2) Neck and middle Full humbucker
Zepp3lin is offline
post #6 of 8 (permalink) Old 12-10-2007, 11:11 AM
Sorry, I guess I wasn't clear
You cannot get what you want with just the 3PS1CGAE5
You CAN get
Just 5 way
If you add a push pull volume or tone switch you can use that to get the other coil tap options
With Coil Tap:
3) Middle split humbucker
5) Bridge split humbucker
So by switching the two switches you can get what you want.
If you don't want the extra push pull, Just leave it out!
Jim
post #7 of 8 (permalink) Old 12-11-2007, 01:23 AM Thread Starter
Reviews: 13
Thks man, aprreciate all ur posting
Zepp3lin is offline
post #8 of 8 (permalink) Old 12-11-2007, 05:43 AM
I have 3 HH and do only the first part (all humbucking).
I have a TZ/SD JB Jr/PAFPRO
The TZ and PAFPRO (I feel) are so loud that my 2 and 4 positions are almost the same as my 1 and 5.
Ibateur is offline
bridge hum , bridge humbucker , coil tap
How to wire up a special 5-way switch? bduersch Pickups & wiring 7 08-15-2006 08:00 AM
YM-50 Switch! Little Fighter Pickups & wiring 3 12-19-2005 03:50 PM
Jpm Switch Observations.... slagaxe Pickups & wiring 2 11-19-2005 11:57 AM
After adding a push/pull switch... cowcowcow Tech: Setup, Repairs and Mods 3 03-26-2002 07:39 AM
Different 5-way switch - why are they different? cowcowcow Tech: Setup, Repairs and Mods 7 03-17-2002 02:45 PM
