High Pass Filter Modification Help - Jemsite
post #1 of 7 (permalink) Old 03-09-2014, 08:59 PM Thread Starter
Guys, I need a little help modifying a JS wiring for a build I'm starting. In a post made at www.satriani.com Gary Brawer (http://www.satriani.com/2000/about/gear/controls.shtml) says when pulled, the volume pot bypasses the capacitor that retains the highs, but I believe the general consensus for newer JS guitars is the volume pot actually engages the cap when pulled.
I have two questions:
1. Can you tell me which one of the above is valid for the attached wiring diagram? and
2. If it is a case of "active when pulled", can you help me reverse the operation so that highs are retained normally and bypassed when pulled?
I hope it is a case of moving the capacitor leads one lug down (each), but it has been quite a while since my electronics classes and I would really appreciate the help.
kissTheApex is offline
post #2 of 7 (permalink) Old 03-10-2014, 08:14 AM
Re: High Pass Filter Modification Help
In this diagram, when it is pulled, the cap is connected to the hot point and the wiper.
So this position allows to keep highs when you decrease the volume.
If you want the same thing but with pushed position, change the capacitor wiring on the switch
ox
oo
oo
to
oo
oo
ox
Heep is offline
post #3 of 7 (permalink) Old 03-10-2014, 09:24 PM Thread Starter
Thanks Heep,
If I understood your diagram correctly, this older wiring diagram for 94-96 JS6000 & JS1000 shows exactly what you recommended. Can you tell me what is the purpose of second row of lugs on the push-pull pot? Are they always connected, no matter the pot position?
Just to make sure I'm understanding it correctly, when the pot is pushed, lugs on rows 2&3 are connected/closed, and when the pot is pulled, lugs on rows 1&2 are connected/closed. Is that correct?
Thank you again.
post #4 of 7 (permalink) Old 03-11-2014, 01:21 PM
Yeah that is right.
However the new diagram you posted shows the opposite if my eyes are not wrong???
Weird... Ibanez mistake or custom switches ?
Heep is offline
post #5 of 7 (permalink) Old 03-11-2014, 01:59 PM Thread Starter
Originally Posted by Heep View Post
Yeah that is right.
No, you are correct. The JS 1200 drawing from 2004 and JS 6000/1000 wiring diagram from 1996 show the operation of the volume pot reversed. Looks like the older JS guitars had the filter on when volume pot is pushed, and the newer ones have it on when the pot is pulled, which also falls inline with Gary Brawer's quote in 2000.
Thanks again for your help.
post #6 of 7 (permalink) Old 03-12-2014, 07:14 AM
One problem is there are some push/pulls that work "upside down" so that pulling them gets you the bottom 4 pins, pushing gets the top 4 pins. If you can beep test the switch you'll know for certain, but I'm just mentioning there's still a chance it'll work backwards with the wrong (right?) push/pull.
frankfalbo is offline
post #7 of 7 (permalink) Old 03-12-2014, 08:24 PM Thread Starter
Thanks. I'll see if I can test the ones I have.
high pass filter , js wiring
High pass filter pot - where to buy? mag8 Tech: Setup, Repairs and Mods 0 12-06-2011 04:10 AM
High pass filter help northlander30 All Other Guitars (including Prestige) 9 01-18-2009 01:30 AM
High Pass Filter guitar425 Pickups & wiring 5 05-30-2007 08:33 AM
High Pass Filter ZeroDrift Ibanez JEM, UV, JS & Other Signature Models 3 01-27-2005 03:18 AM
Where can i get a high pass filter Blackstrat86 Ibanez JEM, UV, JS & Other Signature Models 17 03-16-2003 11:16 PM
