Home Made Guitar Cable Problem. - Jemsite
post #1 of 8 (permalink) Old 12-22-2015, 04:08 AM Thread Starter
Hey Guys
I'm sure someone will have an easy answer for this one.
Im making up instrument cables with Mogami cable and some solid quality feeling plugs i got out of China ( yeah I know ). The problem is the plugs didn't come with the clear plastic sleeve to stop the cables grounding out on the plug casing. So I put heat shrink over the cables to act as an insulator.
The problem is some cables sound like they are lacking in top end, and 1 is dropping signal strength.
I'm thinking the heat shrink is not a good insulator and grounding out the hot signal wire slightly.. does this sound about right? If so, do you have any suggestions for an easy fix without new plugs and remaking 6 cables?
Thanks in Advance.
Andy.
Angelus502 is offline
post #2 of 8 (permalink) Old 12-22-2015, 09:53 AM
RGTFanatic's Avatar
Re: Home Made Guitar Cable Problem.
Try wrapping your solder joints with electricians tape. Use as little as possible while still covering any exposed wire/solder. If this doesn't work, you may have some bad solder joints.
RGTFanatic is offline
post #3 of 8 (permalink) Old 12-22-2015, 12:16 PM
Or you've overheated the cable when making the joints and degraded the cable's own insulation.
Algiman is offline
post #4 of 8 (permalink) Old 12-22-2015, 01:40 PM Thread Starter
I did cut some of the heat shrink off one cable, so it was not touching the hot wire. This seemed to fix the flaws in one cable..hence why I'm strongly thinking its the heat shrink, but its not ideal as any movement will put the hot wire in contact with the casing and then the ground.
RE electrical tape.. its a **** fix.. no offence.. the stuff comes off in heat, then its just messy. I'd rather bite the bullet and cut the ends and put GH or neutriks plugs on, which is a shame coz these cheap plugs out of china are supposed to be gold plated copper, and feel like they are quality, just as is always with china gear, someone forgot the details..
RE. joints and over heat.. My joints are good, maybe to hot seeing as the cable is thick as (I stuck the iron on 430c), but not that messy that I melted the cables insulating shield.
Does anyone know if heat shrink touching the hot and ground is just a no go with instrument cable???
post #5 of 8 (permalink) Old 12-22-2015, 02:08 PM
You don't need to melt the insulating shield to degrade it.
Algiman is offline
post #6 of 8 (permalink) Old 12-23-2015, 11:41 PM Thread Starter
Fixed... The heat shrink must have been grounding some of the signal from the hotwire.
I spoke to a local guy that makes hi end audio cables, he suggested still using heat shrink to insulate the wires from touching the casing, but not to shrink it, that way its still there as an insulator if anything moves, but any contact with the hot wire is minimal. This works perfectly
post #7 of 8 (permalink) Old 12-24-2015, 12:21 AM
RGTFanatic's Avatar
IDK, Heat shrink tubing's entire purpose is to prevent grounding out. Unless it shrank enough to force your signal and ground leads to touch I can't see it being a problem. Either way, I'm glad you got it fixed.
FWIW, if your plugs are getting hot enough to melt the adhesive on electrical tape, you have bigger problems than a messy plug.
Also, there's no telling what's happened inside your new MIC plugs IF you overheated the weld. It may not have hurt the jackets, but could have damaged the inside of the plugs themselves.
post #8 of 8 (permalink) Old 12-24-2015, 08:02 AM Thread Starter
Yeah, maybe the heat shrink closed up the gap between the wires in the plug, but I dont think so. 1 cable the gap was a bit close so maybe that was the one that was losing signal strength.
Re Heat... I have a good soldering station with a 70watt Hakko heater in it, so the welds where done fast, the plugs and welds are fine, im sure the cable insulation is fine too. I had to up the temp to get some heat into such thick cable.
Re the electrical tape.. I live in Australia which is what I ment by the glue comes of in heat, not that I'm melting it with an iron. I hate the stuff, if I have to repair a join that I've used it on years later, its come lose and the glues made everything sticky. Its just nasty.
I dunno on the heat shrink.. I know its supposed to an insulator, and that may be true with voltage and strong signals. But pickup output is such a week signal I have a feeling it was rolling off some top end. Which would make some sense knowing a little about very expensive Hi Fi cables and the time they put in to developing dielectric coatings, and supposedly that the top end tends to travel down the outside of the cable... but that's a discussion on best kept for the audiophile forums. I do know good cables do make a huge difference in high end Hi-Fi, thats why I making up some guitar cables with Mogami cable and gold plated copper plugs ( even if they where MIC ).
All fixed now anyway
cable problem
Home made JS guitar twin5555 Ibanez JEM, UV, JS & Other Signature Models 82 06-16-2014 09:03 PM
FS: GUITAR CABLE LOT OF 4 (GEORGLE L) (BULLET CABLE) (DIMARZIO) guitarjake Classified Ads: Guitars and Gear 2 07-25-2012 09:41 AM
LightSnake 1/4" Guitar cable to USB cable.(Connects guitar to computer via USB) GuitarEvan07 Classified Ads: Guitars and Gear 0 11-24-2007 05:57 PM
cable or guitar problem?? jeffrg270 Pickups & wiring 5 04-02-2004 02:37 PM
Building my own instrument cable? - Made my own Triangle Gear, Equipment, Recording & Off Topic 1 10-13-2001 12:13 AM
