Horribly stuck with superswitch HSS wiring - Jemsite
post #1 of 5 (permalink) Old 09-08-2003, 05:47 AM Thread Starter
Here are the combinations I'd like:
1) Neck and bridge (north coil) - hum cancelling
2) Neck and middle - hum cancelling
3) Neck, middle and bridge - hum cancelling
4) Middle and bridge (south coil) - hum cancelling
5) Bridge only
Can this be done with a 5-way, 4-pole superswitch? I'd quite like to also use a toggle switch to switch the humbucker from series to parallel mode, but I'm not sure if that will work with the coil splitting as well.
Is there someone a bit cleverer than me out there who could give me a hand? It's the humbucker modes that are confusing me...
dot-dot-dot is offline
post #2 of 5 (permalink) Old 09-08-2003, 07:52 AM
Re: Horribly stuck with superswitch HSS wiring
5) Bridge only
yes -- you can do anything with a 24 pole switch.
that's a neat challenge. i think you'd want to run the humbucker through the mini-toggle first, and then tap off that into the 5 way switch.
here's a hint -- to coil cut a humbucker, you connect the seires link either to the hot [which usually gives the screw pole piece coil], or connect it to ground and connect the humbucker hot wire to hot [which usually gives the slug pole piece coil].
if you were tapping off the series/parallel mini-toggle to the 5 way, you would have to find out which of the separate series link wires [since they would not be soldered together anymore] goes to the screw pole coil and which goes to the slug pole coil.
post #3 of 5 (permalink) Old 09-08-2003, 08:58 AM Thread Starter
[edited]
Ah! I did know this, deep down (the guitar has a split/series/parallel switch that I did myself) but having it written down like this has made it a lot simpler...
Would anyone have a minute to think this through for me please?
Humbucker S-, middle and neck cold all connected to ground.
Mini toggle either (series) connects the humbucker N- and S+ together, or (parallel) connects N- to S- and N+ to a wire I'll call MT2
5-way
Pole 1:
Common to output
1: Neck +
2: Neck +
3: Neck +
4:
5:
Pole 2:
Common to output
1:
2: Middle +
3: Middle +
4: Middle +
5:
Pole 3:
Common to output
1: Bridge N+
2:
3: Bridge N+
4: Bridge S+
5: Bridge N+
Pole 4:
Common to S+
1: Ground
2:
3: MT2
4:
5: MT2
Does that do the job? Here's how I've worked it out:
Toggle set to series:
In position 1 I get the neck pickup, then the humbucker N+ to the output and humbucker S+ to ground. The S+ and N- are connected together, so the N- is also grounded and I just get teh North coil of the humbucker
In position 2 I get the neck and middle going to the output
In position 3 I get the neck, middle and humbucker N+ going to the output. S+ and N- are connected together, S- is grounded, so the humbucker is in series
In position 4 I get the middle and humbucker S+ connected to output, S- is still grounded, so it's the other humbucker coil to position 2
In position 5 I get the humbucker N+, the N- and S+ are connected and the S- goes to ground, so that's the humbucker in series
With the toggle set to parallel:
In position 1 I get the neck and humbucker N+ connected to output. The N- is connected to the S- so I get just the north coil of the humbucker
In position 3 I get the neck, middle and humbucker N+ connected to the output. The S+ is connected to the N+ through the fourth pole of the superswitch and the second pole of the miniswitch and the S- and N- are both grounded so I get the humbucker in parallel
In position 5 I get the humbucker N+, which is connected to the S+ through the minitoggle and the fourth pole of the superswitch, so the humbucker is in parallel
Is this right?
post #4 of 5 (permalink) Old 09-08-2003, 01:25 PM
Is this right?
if you can find someone to understand your own custom wiring setups without paying them, then you're one ahead of me! you've clearly mapped it out well. from there, the best way to tell is to wire it up and see what happens. if it is wrong, you will learn how and be able to figure out why, and you'll learn a lot more about pickup wiring than if someone else deciphered your diagram and grunted "yeah."
can you tell i'm a chemistry teacher?
post #5 of 5 (permalink) Old 09-09-2003, 04:24 AM Thread Starter
Good point... sorry if this all seems rather cheeky.
I think it works. I made a full schematic, then emptied my head (didn't take long) and worked through what the schematic would do, and it seems to match what I wanted in the first place...
coil split , coil splitting , mini toggle , neck pickup , pickup wiring , pole switch , toggle switch
Superswitch or not...... Sean777 Pickups & wiring 5 02-04-2013 12:02 PM
Stew-Mac Superswitch Wiring ChaserHUN Pickups & wiring 7 01-25-2013 06:50 AM
4 wire Humbucker wiring and superswitch huruhus Pickups & wiring 0 09-14-2011 04:13 PM
wiring superswitch as a killswitch? Devon8822 Pickups & wiring 2 07-28-2011 07:16 PM
Jem wiring with Allparts superswitch Andy43 Pickups & wiring 0 03-09-2006 04:16 PM
