How can I wire an Evo with 1 vol and output jack only? - Jemsite
post #1 of 4 (permalink) Old 02-09-2005, 06:03 AM Thread Starter
Just what it says. I am butchering a guitar up and all I want is an Evo, 500k volume pot and the jack. I don't want any tapping at all just the hum config. What are my options? Thanks!
Eric
ecalcagnino is offline
post #2 of 4 (permalink) Old 02-09-2005, 07:50 AM
Re: How can I wire an Evo with 1 vol and output jack only?
Simple.
according to you're wiring specifications (dimarzio) combine the two wires coming of the coils and send it to the voulme, along with everthing else, then send the hot output to the jack plug.
I'd recomend having a tone on there mind, evo's are bright as hell.
SpikeSocietySucks is offline
post #3 of 4 (permalink) Old 02-09-2005, 11:07 AM Thread Starter
Yea, maybe you're right. I can just keep the tone pot in the cavity. Much better idea, thank you.
Eric
post #4 of 4 (permalink) Old 02-09-2005, 08:31 PM
Red to the 'in' part of the pot, usually left of center. Green and Bare to the back of the pot. Black and white solder together and taped off. Output from center lug of pot to jack, ground from back of pot to jack. Make sure the bridge ground is on that pot too.
toshiro is offline
Jem 77FP output jack - white wire is not soldered robbie_down_under Pickups & wiring 0 06-27-2007 02:39 AM
9 Pin output Jack for Jem tony777 Pickups & wiring 0 04-11-2007 07:32 AM
Output Jack riconaka Tech: Setup, Repairs and Mods 0 03-16-2006 02:03 PM
Output Jack eg Pickups & wiring 1 12-26-2002 08:54 PM
A new output jack - Will any jack do? SalemB Tech: Setup, Repairs and Mods 6 02-02-2002 03:39 PM
