How hard is it to replace a magnet??? - Jemsite
post #1 of 5 (permalink) Old 02-17-2004, 01:15 PM Thread Starter
Well how hard is it. I would love to try the new Paf joe in the bridge position with an Alnico 5 magnet. I am no expert on pickups (more of an amp man myself ). So:
1) How hard is it??
2) Would I need to rewind the pickup afterwards??
3) Is it worth the hassle???
Freak
power freak is offline
post #2 of 5 (permalink) Old 02-17-2004, 02:48 PM
Re: How hard is it to replace a magnet???
1) How hard is it??
Freak
It's not hard, just pay attention to what's touching what and where the magnetic polarities are when you're disassembling the thing.
No, you needn't rewind.
It CAN be worth it, especially if you know what you're going for.
I turned an F2 into a "dualtone" style pup, replacing the screws with Alnico 5 rod polepieces (to make splitting sound better). They didn't fit very well, so I had to gap fill with wax, but it worked pretty well. I also moved the magnet under the bobbins. It definitely works better split, though I don't like it as much as a bucker now.
edited for accuracy: I used alnico RODS, not BARS
JESTER700 is offline
post #3 of 5 (permalink) Old 02-17-2004, 03:47 PM
1) How hard is it??
if you're talking about replacing the bar magnet underneath the coils, it's not that hard, and you don't need [and wouldn't want to] rewind the pickup, but you should be really careful about a few things.
most dimarzio humbuckers unscrew from under the baseplate, and the bar magnet is jammed between the ends of the pole pieces. to swap in a new magnet, you would want a new one with exactly the same dimensions, or it might not fit [your best best might be to steal it out of a different dimarzio pickup]. also, you want to be really careful with the wires inside, where the pickup cable connects to the wiring of the coils. if you break the hair-thin copper coil wires or their connection to the pickup cable, the pickup is dead, and those tiny wires are impossible to resolder -- i lost an HS2 that way 12 years ago.
i have worried some about the pickup being 'looser' when put back together, since you have to disturb some of the wax potting, but i've never had any additional feedback problems in pickups that i've flipped the magnet.
post #4 of 5 (permalink) Old 02-17-2004, 04:26 PM Thread Starter
Thanks for the replies.
I think I will do it (after my amp making fetish is fully funded ). I think that the Paf Joe with a A5 in the bridge and an Air Norton in the neck would be the ultimate combo!!! Can't wait till I give it a try!!
freak
post #5 of 5 (permalink) Old 02-17-2004, 05:28 PM
Good points about being careful.
As I understand, the biggest benefit from potting in the first place is in the windings themselves. They are generally what become microphonic. So as long as you don't disturb them, repotting shouldn't be necessary.
air norton , bridge position , dimarzio humbuckers , dimarzio pickup , paf joe
Glued magnet mertay Pickups & wiring 3 05-25-2013 03:11 PM
V1 & V2 magnet swap? suffian1 Pickups & wiring 3 11-21-2012 08:27 PM
Magnet swap on F2 and QM2 fly_with_v Pickups & wiring 7 11-13-2012 04:08 PM
How hard its it to replace the Frets on a Jem FP ranman2u Ibanez JEM, UV, JS & Other Signature Models 5 06-20-2008 01:33 AM
How hard is it to replace bridge/picups? Jeff Pickups & wiring 8 09-06-2002 02:53 PM
